Firestone Lifetime Alignment
Old Jul 7, 2007 | 11:56 AM
xLaNcErEvOx's Avatar
I recently curb my rear passenger wheel which probably messed up the toe and caused my steering wheel to be crooked while driving. Its approximately 30 degrees to the right just to go straight. But I have the lifetime alignment with firestone and after I got it done yesterday I looked at the printouts and it looks like they only did the front wheels... My steering is still messed up and I need to get it fixed soon. So is firestone suppose to do a 4-wheel alignment or just the fronts?
Old Jul 7, 2007 | 01:07 PM
CRX2EVO's Avatar
Firestone sucks hard
Old Jul 11, 2007 | 07:54 PM
texasevo's Avatar
i had to get all 4 aligned when i did mine. Plus they had to put a camber kit on it
Old Jul 13, 2007 | 09:13 AM
quickgti18t's Avatar
you know they just do the toe and thats it.... I work at a place like firestone and if your alignment is not even out they move the mirrors a little and it throws the alignment off so they can sell it... Dont take your car to a place that sucks like that...
Old Jul 13, 2007 | 11:18 PM
z4k's Avatar
z4k
Most Firestone only set toe. Toe and Go they call it. I have the lifetime alignment too. I watch the tech everytime. It helps that I used to be an alignment tech.
Old Jul 14, 2007 | 09:07 AM
donour's Avatar
I use only the local firestone shop for my alignment. I get the car realigned no less than once every month and they have no problems with my coilovers or setting them to exactly my specifications.
It's important that you tell them what you want rather than relying on their alignment computer's "recommendations". After all, they're not an evo shop. It's a rare thing that somebody comes in with a clear idea what they want done.
d
EDIT: and contrary to what people are claiming they DO set the camber (and even the caster if you've added a mechanism for adjustment). Again, the problem is that their specs for the evo specifies no camber adjustment up front. If you tell them where to adjustment bolt is or have camber plates, I've found they'll happily set it for you.
steven88
15
Mar 17, 2010 03:41 PM
IXToes
Feb 27, 2010 09:32 AM
turbo271
May 6, 2008 11:37 AM
Jordanz3
10
Jan 11, 2008 09:40 AM
DSMEVOLUTION
30
Jun 10, 2007 06:10 PM
