17x9?? 255/45/17
Old Jul 9, 2007 | 06:43 PM
EVOL2003's Avatar
17x9?? 255/45/17
can u run this size? the tire that are suggested are 255/40/17. i would like to avoid the larger wheel gap, so can i run the 45's without rubbing? not lowered.
Old Jul 9, 2007 | 06:55 PM
EVOL2003's Avatar
come on guys
Old Jul 9, 2007 | 06:59 PM
cc2's Avatar
cc2
Won't work!
Won't work. Rubbing in the rear, or strut clearance in the front.
Old Jul 9, 2007 | 07:16 PM
accident's Avatar
get the 40's and some swift springs, that will fix the gap
Old Jul 10, 2007 | 03:22 AM
richysevo8's Avatar
Dont see the point
Old Jul 10, 2007 | 08:43 AM
boomn29's Avatar
That's what I run on the track currently.
Swift springs
17x9 +35 offset rims with 255/40/17 tires.
Zero issues with rubbing. You might be able to do a 255/45 if you're not lowered, but I can't say for sure as I've never tried.
Old Jul 10, 2007 | 01:21 PM
jjm4life's Avatar
someone correct me if im wrong here, but arent 255/45/17 taller than the stock 235/45/17? i would think that would be less favorable than a slightly shorter 255/40/17.
Old Jul 11, 2007 | 04:59 AM
EVOL2003's Avatar
fail^^^245/45/17 are stock
255/45/17 is just wider
wide/height/rim diameter
Old Jul 11, 2007 | 06:10 AM
nothere's Avatar
well if the 45 number is indeed a percentage of the 255 number then it would be a bit taller, no?
255 is width
45 is a percentage of the width
so in this case you have a taller tire.
255 40 17 is close to the stock tires diameter, 255 45 would be a bit bigger in circumference. throwing off your speedo a little.
as far as looks go 5% would be about 7mm closer to the wheel arch?
remember what you paid for for that information (in case I'm wrong)
Old Jul 11, 2007 | 07:04 AM
EVOL2003's Avatar
255 is width
wrong
"255 45 would be a bit bigger in circumference. throwing off your speedo a little. "
i just was wondering if 255/45/17 would fit without rubbing(on a nine inch rim in diameter) instead of 255/40/17. i am trying to avoid a bigger wheel gap.
i stand corrected
Tire size results
Specification Sidewall Radius Diameter Circumference Revolutions Speedometer Odometer Difference
245/45-17 4.3" 12.8" 25.7" 80.7" 785/mi 60MPH 10000mi N/A
255/45-17 4.5" 13.0" 26.0" 81.8" 775/mi 59MPH 9864mi 1.4%
sorry man
Old Jul 11, 2007 | 07:17 AM
justboosted02's Avatar
Just use this for all your size/aspect ratio questions
http://www.miata.net/garage/tirecalc.html
Old Jul 11, 2007 | 08:36 AM
jjm4life's Avatar
knew i wasnt wrong... haha
Old Jul 11, 2007 | 11:00 AM
letMeIn's Avatar
you didn't tell us the offset of the rim. but I think you may have some rubbing issues in the back.
Old Jul 11, 2007 | 11:33 AM
shbomb8188's Avatar
Stock is 235/45-17.
Old Jul 11, 2007 | 11:39 AM
EVOL2003's Avatar
35 is the offset i think
i talked to zoeb from subydude.com
specificly for evo
