The Official Wide Tire Thread
Old Oct 29, 2013, 02:00 PM
  #526
Dallas J's Avatar
Originally Posted by griceiv
i found these and they look quite interesting. completely custom offsets available and CHEAP!
http://www.vorshlag.com/product_info...roducts_id=601
i'd probably go baller and get some 12's.
So who's going to be the first to buy a set and check brembo clearance for us?
For that price, I'm definitely interested in picking up a set this winter as long as inside clearance isn't an issue. Ill figure out external clearance once they're mounted
Old Oct 29, 2013, 04:30 PM
  #527
nollij's Avatar
Not I! This is all research for my 2015 setup. I don't terribly like buying things 1 year in advance because of the the whole "Time Value of Money" thing and how the stock market is doing. But, if no one pulls the trigger by August-September of next year, I guess I will be the first one out of the gate.
The other thing I have to settle on is spring rate (for road course, not AutoX). I haven't done much research into that yet to warrant pulling the trigger. Currently, I am considering 12kg/mm front and back and going to stiffer sway bars if I need more roll resistance. 14kg/mm would be the max I would think I would need unless I ran some very aggressive aero.
Old Oct 29, 2013, 04:54 PM
  #528
RJones's Avatar
With my current 18x11 +25 I have to run a 20mm spacer in the front for clearance with the spring/shock. For an 18x12 I'd need to be at -8 offset for the same clearance, so I'd have to run a 44mm spacer with these. Sounds iffy
Old Oct 29, 2013, 11:46 PM
  #529
griceiv's Avatar
Originally Posted by Kada__85
ive been toying with the idea of running 18x10.5+22 te37sl with 275/35 rs3. do you think i could run these with minimal issues other than a roll and pull? or should i just go with 18x10 +20 and 265/35
I don't think either of those wheels will be an easy fit. It will take substantial body work to make either fit in the rear.
Old Oct 30, 2013, 08:07 AM
  #530
Dallas J's Avatar
FilthyEvo verified that the ForgeStar F14 clear brembos up front without a spacer on the 18x10 +18. May be a little closer on something in the +25-30 range for the 11" wheels, but spacers will fix that.
Old Oct 30, 2013, 09:14 AM
  #531
nollij's Avatar
Can you please take measurements of the clearance on the inside of your wheel well up front?
What is the OD of your coilover springs?
So, you are on 18x11 +25 with 20mm spacer up front with 285/30/18 BFG R1-S that have a section width of 290mm and tread width of 292mm. Actual measurements of your clearances would help move this forward.
My tires clear the back of the fender with the Perrin PSRS and Ciro plates. The only rub I noticed was on the side of the transmission case but I would not go full lock while on the track so that clearance does not concern me too much.
Old Oct 30, 2013, 11:22 AM
  #532
RJones's Avatar
I won't be able to do that for a while. I don't have any race tires, and the car's not running, so I won't be racing any time in the near future. I've also never run the 18x11s with BFGs. They were from my Hoosier days. I had been running the BFGs on 18x10.5s.
Old Nov 16, 2013, 10:18 PM
  #533
gotspeed's Avatar
need help,
I went through all 36 pages and NOT one person(Evo9) running 18x9+29 with 275/35, what else do I need to make this fit beside pull,roll, add neg camber and bolt relocate. thx
Old Nov 16, 2013, 10:33 PM
  #534
evobros's Avatar
In sure they will fit fine with just what u said^^^.
Old Nov 19, 2013, 06:18 PM
  #535
hiboost2.0's Avatar
Minimal issues is an understatement brotha. You would really need to pull the rear and relocate the bumper bolts. Really depends on what look you want and your ride height though.
Old Nov 19, 2013, 06:22 PM
  #536
RazorLab's Avatar
Received 1,044 Likes on 762 Posts
Originally Posted by gotspeed
need help,
Rear roll, bolt relocate
Front negative camber and they will wear the front fender liners a tad. You will also hit the frame rail on full lock.
I currently run 18x9 +30 with 265/35 and they do all of the above.
Old Nov 19, 2013, 10:29 PM
  #537
gotspeed's Avatar
^^ going back to tuning Evo, Bryan?
I'm running 18x9+29 with 265/35 for a while now have no sign of any contact with the frame rail only with the fender liner. I have maybe about 2" gap ride height up front and about 1" in the rear
Old Feb 13, 2014, 08:57 PM
  #538
211Ratsbud's Avatar
Excuse me gents':
I snagged some 18x10 +25 wheels. I want to run a 285. is this a good match for that width wheel?
Also, is a 285 on 10" rim @ + 25 going to cause inboard issues IE trailing arm etc front or rear? The outside of the body work is taken care of. Not concerned with adding camber caster or other nonsense other than what a proper alignment would require.
Old Feb 14, 2014, 01:44 AM
  #539
TougeGod7's Avatar
Originally Posted by 211ratsbud
Excuse me gents':
that will work ONLY if you have a widebody
Old Feb 14, 2014, 03:34 AM
  #540
charlie.tunah's Avatar
I <3 this thread. Best thread on EvoM
Quick Reply: The Official Wide Tire Thread
