The Official Wide Tire Thread
Old Dec 23, 2014 | 06:39 PM
  #676
deeman101's Avatar
If you don't mind, what did you pay for the pull and repaint?
I got a lot more than just the wheel clearance done but I'd guess that would cost $1500 to $2k.
Originally Posted by R/TErnie
Buy the damn trailing arms, run 10.5's, and give me money so I can buy more Evo parts.
I would....if there were wheels with high offset that I was interested in. The wheels I would want in 18x10.5 are all low offset.
Originally Posted by Grimgrak
Why not just 18x10 +25 285/30/18 and be done with it? Spacer as needed.
That would not clear any better than 275 on 18x10.5. But would have tire bulge that would take away from handling sharpness.
Old Dec 24, 2014 | 07:01 PM
  #677
kaj's Avatar
kaj
Originally Posted by deeman101
I would....if there were wheels with high offset that I was interested in. The wheels I would want in 18x10.5 are all low.
I would too, if I could find some used. LOL. once I factored $500+ on top of a set of wheels and tires, I decided to just stick with 255s.
I'll worry about all that if I get to a point where I need it to be competitive.
Old Jan 7, 2015 | 10:08 AM
  #678
joeymass93's Avatar
do you have pics of the 255's?
Old Jan 7, 2015 | 12:01 PM
  #679
kaj's Avatar
kaj
i can look when i get home. they are standard fitment. nothing crazy. i'd run 265s if Hankook made that size in a 17" tire.
Old Jan 12, 2015 | 09:28 AM
  #680
R/TErnie's Avatar
PF01's are cheap, anything CCW or Forgeline will work, Work Wheels Professors...
Look at MKIV Supra fitments, their rear wheel fitment is very similar to what you'll need.
Old Jan 12, 2015 | 06:53 PM
  #681
deeman101's Avatar
Those are options but none of them appeal to me for either aesthetic or strength/weight/proven durability reasons. The ones that would are pretty expensive and would make the fender clearing look more feasible.
Old Mar 14, 2015 | 05:14 AM
  #682
NigHtcRawl3R's Avatar
Thought I'd bump this thread up. Running 295/30, Enkei RPF1's 10.5 +15. I currently don't have enough material to start a build thread but thought I'd contribute to this thread.
This is how she sits at the moment. Currently getting a full 8 point cage put in
Old Mar 14, 2015 | 06:30 AM
  #683
Grimgrak's Avatar
How would it not clear any better than a 275/35? The 30 sidewall with extra width would handle better and squirm less than your 9.5 35 setup.
Old Mar 15, 2015 | 09:07 AM
  #684
deeman101's Avatar
The tire would interfere in the same place it already does. It might clear better closer to the rim but by that point the camber curve increases sharply. Its hard to see with the overlay but 18x10 does have tire bulge. 10.5 has a slight stretch which makes things like turn in feel more taunt. I found it noticeable going 265 to 275 on 9.5 rim at least.
Old Mar 16, 2015 | 06:39 AM
  #685
Construct's Avatar
Nonsense. A build like that deserves a build thread. Post it up if you get the time, because we'd all love to see it.
Old Mar 23, 2015 | 10:09 AM
  #686
heel2toe's Avatar
Does anyone here still have their fender liners up front with shaved rolled or spaced out front fenders? Im trying to figure out how to keep those tucked up after the fender has been altered. It seems most people simply remove the liner but I'd much prefer to leave it on there and massage it with a heat gun but Im not sure how its supposed to stay in place considering it attached to the fender in 2 places...
Old Mar 23, 2015 | 11:58 AM
  #687
Grimgrak's Avatar
Somehow I think a 10mm drop in height will be more effective at reducing "squish" than the additional 10mm in width it brings.
Did you drop any sidewall height going from 265 to 275? Doesn't seem like it.
Old Mar 23, 2015 | 12:43 PM
  #688
griceiv's Avatar
yep. just trimmed or reformed with heat gun.
Old Mar 23, 2015 | 12:57 PM
  #689
heel2toe's Avatar
So I get the reforming with heat and trimming but what was done to keep them tied to the actual fender up and out of the way? IIRC you said you had your fenders reshaped with a hammer and dolly?
This is why I was hesitant to cut them as I figured I would be cutting away the attachment point vs rolling it where there would still be a little lip to tuck up underneath. However I suck with body work and cracked my fender so I need to source a new one and figure out how Im going to make room. Dont want to break another one...
Old Mar 24, 2015 | 08:06 AM
  #690
griceiv's Avatar
nothing. they just stay out of the way.
