Body roll
Old Aug 4, 2007 | 03:08 PM
  #31
belizelittle39439's Avatar
Good deal.
I was experiencing bit of understeer, but then I've got the front end lowered, and so I NEED the roll center correction kit.
I've been seriously thinking about doing a rear sway at 25mm...but I'll wait until after a couple autocrosses first.
Old Aug 4, 2007 | 03:22 PM
  #32
Warrtalon's Avatar
My Vishnu/Gerrard Ohlins setup is designed to use spring rate and custom valving to make the car handle properly. I have the 700/900lb spring rates, and the car is very neutral. I increase pressure in the rear by 2-3psi, which gives me just enough front traction to slide every so slightly when traversing autox elements. It's not a full slide, but just a little bit of rear slide to help me rotate and transition nicely.
Old Jun 28, 2009 | 12:40 AM
  #33
red evo8's Avatar
sway bars are the first thing to install when dealing with body roll, the springs play a part in it but 60% is the sway bar.
nismo3183
Sep 25, 2013 07:04 AM
2nd try
Aug 23, 2011 11:32 AM
black evil evo
38
Jul 18, 2011 08:01 PM
george3
Northeast Region
Nov 23, 2008 12:14 PM
blackonblackevo
65
Aug 5, 2007 12:34 AM
