alignment spec suggestions
Old Aug 20, 2007 | 07:18 AM
4cdndctn's Avatar
Originally Posted by XK120
Ya maybe I should have clarified, when I said toe out, I meant something drastic like what 4cdndctn posted.
And maybe I should provide my correct specs instead of going off bad memory
f: camber = -2.7 / toe = 1/8 out
r: camber - -1.4 / toe = 1/16 out
Old Aug 20, 2007 | 07:34 AM
donour's Avatar
Originally Posted by SmikeEvo
And the front of the car is still heavier. Traditional susp. set ups will favor the front. Even if the Evo came favoring the rear changing to a front bias could get the job done.
This argument only makes sense if you're talking about wheelrate, not springrate. Remember, the front and the rear have different geometery. The front springrate may be lower, but the effective rate is still higher.
It boggles my mind why someone would change the the F/R springrate ratio without trying to address a specific defect in the stock one.
d
Old Aug 20, 2007 | 07:47 AM
XK120's Avatar
That's better
Old Aug 20, 2007 | 07:50 AM
EvoBroMA's Avatar
i noticed the japanese race teams seem to run the opposite of US philosophy with suspension.
we typically run the same size tires all the way around and higher spring rates in the rear, to help with rotation.
In Japan some teams treat the Evo similarly to their weird JDM FWD setups, they have higher spring rates for the front, but they also compensate with a staggered wheel setup. larger wider wheels up front with a lower profile, and less of a profile on the rear. I know on other boards the speculation as to why they run this, is that it gives more steering response mid turn - and suits a more aggressive driving style.
i'd love to hear what you guys think of this.
evox26
Jun 5, 2017 07:03 PM
Roen
12
Aug 15, 2013 08:33 PM
namwens
Nov 4, 2009 01:13 PM
idriveanevo
11
Jun 16, 2009 09:45 AM
outsider
27
Dec 14, 2004 08:24 AM
