Adjusting ride height with Tein Flex Coilovers...?
Ok, quick question. Ive searched and read the TEIN install manual which has me more confused than anything.
There are the lock washers that hold the spring up, and there is another big washer and the end of the shock. To adjust the ride height, ive read that you can loosen the bottom washer, and turn the damper to raise & lower it, then tighten up the washer.
or
Do I loosen up the big washers that hold the spring up, and move those up/down and allow the spring to expand or tighten? Thanks
or
I got the TEIN Flex Coilovers put on a few minutes ago... the rears have 2 finger wheel gap, and the front have 3 finger wheel gap. Rears are RIGHT where I want them... but the front is still a little high for my taste.
Is there any easy way of lowering the front? I've thought about loosening the very low lock ring, and just turned the shock until it lowers it... or is this not the correct way to do it? Let me know...thanks.
I would jack the car up and adjust the height on the coilover that way.Also are you using a tape measure to measure the gap?You want to have the car off the ground when you are adjusting the coilover so as not to have any weight on the shock when you lower it more.Also try to adjust the coilovers on as level of ground as possible.
What im trying to say is, that I dont know HOW to adjust the coilover... Ill worry about the tape measure when I learn how to move it up or down. That is the point of this thread.
Dont adjust your height by altering your spring preload. Just freaking loosen up the strut housing man! Twist the bottom counter-clockwise to make it taller, clockwise to shorten the damper height. Make sure you lock the lower collar AFTER you tighten the rear strut to the lower control arm.
This thread is ancient but maybe someone can help me out. I just got an 03 evo with the tein coilovers. Tein springs in the front and eibach sport line in the rear. When I put the car on jack stands all the springs were really loose. I was able to move them up and down about a half inch. Is that how they are supposed to be with the tires off the ground? I wanted to raise the car up a little but those bottom collars are not budging as of now. I was able to loosen all the spring load collars. I was thinking of adjusting those collars and just making the springs snug. Hopefully what I wrote makes sense. Thanks.
Most coilovers require some level of pre-load. Im not familiar Teins preload recommendation, but you need to address this ASAP
At the very least, snug the springs up so there is zero play, by adjusting the lower perch. You should refer to your Tein installation instructions to verify
03EVO-VIII
28
Oct 12, 2021 06:33 AM
Faust
76
Nov 6, 2018 06:47 PM
Green_Bandit
May 26, 2017 10:02 PM
jdizzle37
67
Feb 4, 2017 05:37 PM
