Looking for UN-drilled/slotted 2 pc floating front disks
Old Aug 23, 2007 | 10:05 PM
RaNGVR-4's Avatar
Hey guys, ive been looking around, and reading up on all the stock size 2 piece floating disks available for the evo's. I really like the vane design's of the racing brake and stoptechs(my favorite) but they dont seem to come with blank rotors. I hate slotted/drilled/dimpled rotors. I never liked them on track, at auto-x's, or on the road. Theyre noisy, have less disk surface area, and they destroy pads way too fast. The only advantage ive ever experienced was in the wet, but that isnt a big enough trade-off for me. If any vendors or informed people can point me in the right direction, I would greatly appreciate the help. Thanks
Ryan
Old Aug 24, 2007 | 04:29 AM
ghoonk's Avatar
Interesting you should mention that, because I'm currently using Performance Friction Direct Drive 2-piece rotors with PF11 compound pads and have found them to be durable, quiet, and cost-effective.
On the other hand, my Endless SS pads / stock Brembo rotor combination used to suffer from pad AND fluid fade, generated a truckload of dust, and was actually noiser than my current setup. I've never come across non-slotted/drilled/dimpled 2-piece rotors myself, but am keen to find out if they really are that much better
Old Aug 24, 2007 | 11:16 AM
RaNGVR-4's Avatar
more surface area > any benefit from slots in the dry. less chance of "warping" ect. you cant compare those two setups as they used different pads, so its moot really.
the performance friction disks are just dimpled, thats better, but not ideal. their vane design is not what im looking for however. im picky, haha
Old Aug 24, 2007 | 11:17 AM
rcheung's Avatar
What car is this for? I see many different cars in your sig.
Old Aug 24, 2007 | 11:19 AM
RaNGVR-4's Avatar
Its for an Evo, hence why im posting in the evolution forum
Old Aug 24, 2007 | 11:59 AM
GTWORX.com's Avatar
Stoptech has a blank face 2 pc. rotor available, coming in 1 month.
- Andrew
Old Aug 24, 2007 | 02:01 PM
RaNGVR-4's Avatar
- Andrew
Are you positive? Any prices? Because if thats a fact, I would be willing to get on a pre-order list. thanks
Ryan
Old Aug 26, 2007 | 06:16 PM
Balrok's Avatar
Have you tried calling Porterfield brakes yet? They will make custom rotors with i think 7 different options in vane design, then whatever material you want, 2 piece or 1 piece...etc etc etc. I just had them make me a set of Raybestos ST-43's for my evo. They even took the time to grind out the areas for the rear's (the moon shape on the bottom) to fit on a 2 piece and also made the fronts the full dimensions so they won't jutter around and make noise, without me asking them to . Can't wait to get them on. If you do call, let us know what they want for a set and what options you chose!
http://www.porterfield-brakes.com/catalog.pdf
page 46
Old Aug 26, 2007 | 08:25 PM
Max Power's Avatar
It might be worth a shot getting in touch with RacingBrake.
http://www.racingbrake.com/main/contactus.asp
Old Aug 27, 2007 | 01:04 AM
Bonestock!'s Avatar
http://www.buybrakes.com/store/BAER-5611001
I know it shows a pic of a drilled and slotted rotor but the surface is "plain" in the description.
Old Aug 27, 2007 | 11:36 AM
RaNGVR-4's Avatar
no hat venting and plain disk venting. no-go. im picky, remember? lol
mikebuff35
25
May 12, 2015 09:13 AM
XIRMOVE
Aug 25, 2008 05:01 PM
Tonykwok
14
Mar 9, 2006 06:51 AM
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
Jul 19, 2005 10:12 PM
