what spacers???
Old Oct 22, 2007 | 12:54 PM
Ct9aGsR's Avatar
what spacers???
i planning on getting some rota P45's 18x9.5 i have tanabe lowering spring and tires im planning on getting some falken azenis rt-615 245,45, or 40 , 18's which should i go with? and what size spacer do i need in the front?
Old Oct 23, 2007 | 09:45 AM
Evotech8's Avatar
If you have the +30mm offset wheels you will need 5mm spacers minimum, but i HIGHLY recommend a 6 or 7mm spacer. With a 5mm spacer the P45R spokes up front comes within "paper thin" from hitting the brembo's. I had a machine shop shave a 8mm spacer down to a 6mm and it works out perfect.
I would stick with 245/40's if you don't want rubbing issues.
Old Oct 23, 2007 | 10:23 AM
Ct9aGsR's Avatar
so just get a 6mm spacer and it should clear fine?, and do i have to roll the rear fenders? thanks alot man for the help
Old Oct 23, 2007 | 11:42 AM
Evotech8's Avatar
With 245/40's, no fender rolling. 255's and wider, yes.
I run rt-615 245/40's with no problems.
Old Oct 23, 2007 | 01:33 PM
spooch's Avatar
my buddy has a set of p45r wheels on 245 40 17 tires with spacers but it shakes a little bit on the highway on his evo, would that be because its out of alignment??? Or do you need extended wheels studs?
Old Oct 23, 2007 | 01:45 PM
Evotech8's Avatar
Last time I heard Rota does not make P45R's in 17's.
Old Oct 24, 2007 | 06:49 AM
spooch's Avatar
i mean 245 40 18... its a 8mm spacer... would this be making it shake?? Does it need to be 6mm only?
Old Oct 24, 2007 | 09:18 AM
Evotech8's Avatar
Shaking could be caused by two things:
1. wheels/tires need to be re-balanced.
2. Always use quality evo 'hub-centric' spacers, not those crappy universal size cast spacers. A few I've seen wobble on a flat surface and are not centered because the hub bore is too big.
Old Oct 24, 2007 | 09:42 AM
spooch's Avatar
i think he has the autozone or pepboys spacers, i will find out...
is there a certain brand your prefer?
Old Oct 24, 2007 | 12:58 PM
Evotech8's Avatar
H&R, KICS, ICHIBA, or custom spacers from wheeladapters.com
dave_evolvix
40
Sep 21, 2016 04:39 AM
ToddMcF2002
Dec 28, 2009 05:06 PM
3ktt
Jul 22, 2009 12:07 PM
EVO8speed
Apr 6, 2009 11:20 AM
Evo9tunerz
Mar 29, 2009 09:40 AM
