Factory Alignment
Old Oct 26, 2007 | 05:09 PM
06RS's Avatar
Factory Alignment
I've heard from a few people that the Evo comes from the factory with negative camber. Looking at my original set or Advans after 10k miles, it was obvious that this is the case (the Advans were much more worn on the inside). Does Mitsubishi set the camber that way for handling at the expense of even tire wear?
I got a new set of wheels with a fresher set of Advans, and I'd like to get as many miles out of them as possible. I'm considering getting the car aligned, but I'm concerned that an alignment may affect handling in a negative way. Being that the Evo's steering feel is as razor sharp as it is, I'm concerned that I may jeportize that incredible steering feel.
Any input would be appreciated.
Old Oct 26, 2007 | 06:51 PM
atombomb33's Avatar
EvoM Community Team
It's the toe setting that kills the tires. Make sure you zero out the toe on all 4 wheels and that should help extend the life of your tires.
Old Oct 27, 2007 | 04:42 AM
Jspec EVO VIII's Avatar
Gotta agree w/that. I'm getting my allignment done soon, since the driver side tire's inside was worn.
Old Oct 27, 2007 | 09:30 PM
jsknockoff's Avatar
Ive gone through 2 sets of tires on mine in 6500 miles. Passenger side was the worst on my car. At 3500 miles it wouldnt pass PA state inspection because of the severe wear on the front tires. Ive been trying to get mine straitened out ever since, 2 alignments later and still burnin them up. Good luck.
Old Oct 28, 2007 | 10:50 AM
barneyb's Avatar
The Advans are so stiff they will wear on the insides due -1 degree of camber while other tires won't. A lot of the razor sharp handling ot this car comes from the Advans so you pay for your thrills.
Old Oct 28, 2007 | 01:14 PM
ballallday89's Avatar
The inside of my tires are completely bald too. But once its past the first ring the treads perfect. Will the tire warrenty i bought pay for this? or does mitsu not care lol. BTW My tire warrenty is if you damage your rim or get a flat theyll replace it for free....ive already had it happen so i know it works but will this fall i nthe place of that too?
Old Oct 28, 2007 | 07:19 PM
jsknockoff's Avatar
Nope. They refuse to cover any tire for wear related issues.
