17s vs 18s
Old Dec 21, 2007 | 05:39 PM
Str8Nasty's Avatar
Great thread... I was wondering if I should get 17 or 18s
Old Dec 21, 2007 | 05:43 PM
MitsuJDM's Avatar
Originally Posted by CEB Unit
17x10's 255/40/17 Nitto NTO1's Good response. Waiting to take track the car.
What fender mods/wheels spacers are needed for this size combo?
Old Dec 21, 2007 | 05:53 PM
fugiwara's Avatar
there are 18" wheels out there are lighter than stock 17", or the same weight, I don't think there is any disadvantage to those 18"
Old Dec 21, 2007 | 05:57 PM
CEB Unit's Avatar
offset is 18+fronts and 38+rears. No spacers needed but have a small 2-5mm spacer in the rear. Don't remember which one was given. Not all cars will require it. Fronts were pulled and the rears rolled/shaved. All work done by robi at robispec.com
Old Dec 21, 2007 | 07:48 PM
mrich82's Avatar
Get that same lightweight 18" wheel in their 17" wheel and save even more weight... so I'd say the advantage is still 17" because of decreasing weight.
I do see your point though, you could run those 18" wheels and not gain any weight from the stock wheels. I'm currently wheel shopping for next spring/summer and trying to decide between 18" or 17"... I'm also leaning towards the Advan RS in 17x9 like someone else posted here.
Old Dec 21, 2007 | 08:21 PM
Bexa20's Avatar
Originally Posted by TougeGod7
did you have to roll your fenders with those wheels?
Yes he does have them rolled. Actually he had to roll the front fenders as well, he was rubbing on a bigger bumps while turning. We found out about this during the autox. I think its due to the wide rim and +25 offset.
The whole setup looks very nice, rolled fenders - you can't even tell. Him and I we rolled the rear ones, he did the front ones few days later after we found out it was rubbing on the edge of the front fender lip.
If you are local and want your fenders rolled, give him a call, he will hook you up. Profesional work, not a garbage that we saw many times.
Old Dec 21, 2007 | 09:02 PM
atombomb33's Avatar
EvoM Community Team
18s or 17s is a good discussion. If you choose the right 18" wheels and tires, they'll be lighter than 17s. All depends on which wheels and tires you choose. The most important part is width for more contact patch.
Old Dec 22, 2007 | 05:31 AM
redlaybal's Avatar
yah i just went 18 for looks!!i told myself a inch doesnt make a big difference but i think im wrong now. lol
Old Dec 22, 2007 | 08:09 AM
sleet's Avatar
I stayed with 17's <3
P45R 17x9 w/ BFG KWD2 255s
Old Dec 22, 2007 | 08:20 AM
atombomb33's Avatar
EvoM Community Team
Another thing to consider in this discussion. If you want to go with a big brake kit, you'll need 18s so the new rotors/calipers will clear. I don't know if all big brake kits won't clear 17s, but at least the overwhelming majority. But, you only need a big brake kit if you're racing on a road course.
Old Dec 22, 2007 | 08:22 AM
belizelittle39439's Avatar
^^ Good point.
but is it possible though to simply upgrade the lines and pads on the current calipers to accomodate a road course?
Old Dec 22, 2007 | 01:24 PM
jjm4life's Avatar
^^ there are plenty of race evos running stock brakes with just upgraded lines pads and rotors. i belive the cyber evo still runs stock calipers? love my 17x9.5s
Old Dec 22, 2007 | 01:31 PM
atombomb33's Avatar
EvoM Community Team
Yeah, you can still run stock sized rotors and calipers with upgraded pads and rotors. And that set up will work great. I only mentioned the BBK for those who are super serious about road course racing and would need a BBK.
Old Dec 22, 2007 | 02:05 PM
jmsrx's Avatar
So, do the big name time attack vehicles (AMS,HKS, etc.) run 18's because of the clearance issues with larger brake kits or because of the larger contact patch or for some other reason?
Old Dec 22, 2007 | 06:18 PM
Shaun@AWDMotorsports's Avatar
Originally Posted by BigBallin
what do you run and why? i currently run 18x9 but was thinking about going to a 17. seems like there are more tires to choose from in 17 and plus i drag the car to that might be a little benifical to me.
go with the 18's advans rs
