Spacers?
Old Jan 24, 2008 | 05:12 PM
Kemist's Avatar
Spacers?
I know this has probably already been discussed but I couldn't find the thread. I have the stock enkei's (evo 8) and I want to use a spacer for a more aggressive look, but not so much that it rubs or throws of the geometry of the suspension. 5 or 10mm seems to be what I have heard is the way to go. Suggestion, comments, suggestions on which brand is good would be appreciated.
Old Jan 24, 2008 | 08:33 PM
rjdevo9_mr's Avatar
according to Road Race Engineering, don't go wider than 10mm even if you have extended threads
Old Jan 24, 2008 | 08:36 PM
gixxerman11's Avatar
10 mm will be just fine
Old Jan 24, 2008 | 08:49 PM
jenx1976's Avatar
im running 20mm F and 10mm R (kics) on stock 8 enkies., Espelir GT springs -2.5F and 1.5R camber with no issues.
Old Jan 24, 2008 | 08:54 PM
Normanruben's Avatar
i would say 10 mm. for the stocker. h & r.
Old Jan 25, 2008 | 01:18 PM
Kemist's Avatar
thanks for the input!
Old Mar 7, 2008 | 07:45 PM
PainInMySide's Avatar
If you use a 10mm spacer, do you need to replace the lugs with longer ones?
Old Mar 7, 2008 | 08:50 PM
EatSleepBoost's Avatar
^ posibly swap out the studs. not lugs. i think thats what u mean to say
Old Mar 8, 2008 | 06:10 AM
Oh, right. I totally mean studs. I've been looking at some spacers and a lot of them come with studs anyway. The cheapest one that I found is sold by Racing Brake but they don't come with studs. Those can be found here: http://www.racingbrake.com/MITSUBISHI_s/3232.htm A set that I found to come with spacers are about twice as expensive. Those are here: http://www.racerwheel.com/wheels-whe...itsubishi.html
