Nagisa lower front and lower rear arm
Nagisa Front Lower Arm
Nagisa Rear Lower Arm
I was going to get these because i wanted to track my car. i want full control of adjustment. my tax return is coming and i know this stuff is expensive but thats ok. Has anyone had experience with these lower arms?
if your car is a dedicated track car, then you will definitely benefit the full control of adjustments from it.
but if your car is also your daily driver, then i suggest you stick w/ stock components. They will bent and get damaged in no time if you plan on driving it on the streets..
i thought that this will level the car since when you lower it with full coilovers the car will make the lower arms v shape. doesnt this help to straighten it out? doesn't that also help with the daily drive?
just get the whiteline roll center adjusting kit if you are looking to upgrade. its cheaper and works almost the same.
it will help in performance perspective but it does not mean it will be suitable for daily driving. street potholes and rough roads will destroy these in no times. its completely waste of money for street car.
I just have full coilovers, front and rear strut bars, a 6 point under brace, and a rear trunk bar.
