Noises After Spring Install?
Old Jan 29, 2008 | 05:42 PM
bboy_RES's Avatar
finished installing the front springs on my car and i drove it off of the driveway so i could park backwards and work on the rear springs. i noticed that when i turn the wheel all the way to the left and then turn it 1/4 to the right it makes a knock sound. i also hear a creaking noise after i turn the wheel 1 full turn either left or right. what are the noises that i'm hearing? will it go away after i get an alignment? i hope it's just because the springs are breaking in. please lemme know asap. thanks.
Old Jan 29, 2008 | 05:43 PM
Silver06evo9mr's Avatar
damn third one today at least...
my thread:
https://www.evolutionm.net/forums/sh...32#post5194832
Old Jan 29, 2008 | 05:46 PM
prj.evo's Avatar
the springs are probably just seating. There are 1,XXX threads on this you might find some more results by searching.
Old Jan 29, 2008 | 07:48 PM
bboy_RES's Avatar
well im 100% sure the knocking noise is coming from the front left wheel. if it doesnt stop im gonna reinstall the shock/spring and see if it goes away.
Old Jan 30, 2008 | 07:32 AM
awd_ftw's Avatar
Sounds like your springs are settling or something wasn't tightened back down properly. Recheck your steps and be easy on it for the time being
Old Jan 30, 2008 | 07:40 AM
alexsracing's Avatar
either too loose or not seated
did you at lease put the rubber from bottom of the old spring on the new spring?
Old Jan 30, 2008 | 09:29 AM
bboy_RES's Avatar
yeah i put the rubber on the bottom of the spring. im gonna reinstall the shock/spring again.
Old Jan 30, 2008 | 11:43 AM
bboy_RES's Avatar
So I checked the spring and it looked like it was seated properly, but I went ahead and reinstalled the spring on the shock anyways. Now the steering wheel turns smoothly both ways and there's no more sounds. So do I have to break the springs in before I get an alignment or does it matter?
Old Jan 30, 2008 | 11:51 AM
bboy_RES's Avatar
it would help to drive around a little that way its settled before the alignment and you won't need to re-align again
Old Jan 30, 2008 | 12:57 PM
bboy_RES's Avatar
i probably have 150-200 miles on them already. i also tried taking a couple off ramps a little fast. i think they've settled now.
Old Jan 31, 2008 | 09:04 PM
bboy_RES's Avatar
Okay now I'm worried. The noise went away for a day, but today I drove to murrieta and on the way I started hearing a deep rumble from the left front wheel well and I could feel the vibration with my feet. They happen when I'm driving straight and they only last for a split second. Then when I made a left turn into a parking spot I straightened the wheel and something felt like it dropped from the front left shock. Sometimes I feel tension when I try to turn the wheel fully to the left. Wtf is going on?
Old Jan 31, 2008 | 09:24 PM
bboy_RES's Avatar
Sorry double post.
Old Jan 31, 2008 | 10:25 PM
richevo26's Avatar
just got this problem 2 days ago on my IX, and i only have tanae gf-210's. The springs have been in the car for months so i dk wuts goin on
Old Feb 1, 2008 | 01:26 AM
bboy_RES's Avatar
i think i might've figured out the problem. i searched and read a couple threads about people that had a similar problem and some people recommended to lubricate the front strut bearing. i dunno what lube to use, but i have some engine assembly lube. it says its good for bearings and prevents metal to metal contact or something. i'll try using that and see if it solves the problem.
