alignment w/ TEIN FLEX
Subscribe
Jul 25, 2003 | 10:42 PM
how does this work? should i keep my fact alignment specs and just reallign or do i got to change my settings a lil bit to get it right?
Reply 0
Jul 27, 2003 | 02:10 PM
Realign after tein install as close to exact factory specs as possible.
Reply 0
Jul 27, 2003 | 09:58 PM
whatever, get a tad more negative camber in front. And a tad less negative camber in rear. And as much positive castor up front if possible.
Reply 0
Jul 28, 2003 | 12:49 PM
why would you want less camber in the rear boostedwrx?
Reply 0
Jul 28, 2003 | 12:54 PM
make the rear more tail happy! =)
Reply 0
Jul 28, 2003 | 01:09 PM
I have the Flex. Here are my settings.
Front
With the Tein Flex camber plates set to full positive, the camber is set to -1. By doing this you can set your camber to -6 if you want on the stock bolt holes.
Toe is set to -1 in the front
Rear
Camber: -.75
Toe: 0
Reply 0
Jul 28, 2003 | 01:13 PM
handle better than stock??
Reply 0
Aug 6, 2003 | 11:17 PM
but who told u these settings? and i thought alignment there are more settings than just that
Reply 0
Aug 8, 2003 | 10:08 AM
i want to run -2 up front and -1 in the rear when i get aligned...
Reply 0
Aug 8, 2003 | 05:04 PM
We have found -1.5 degrees all around works well as a compromise between good turn in, good rear end stability in fast sweepers, and still not extreme enough to induce poor tire wear 9though your mileage may vary!)
You should let things settle for around 300-400 miles before aligning it all, and while on the rack, go over everything and check torque specs to be sure.
Adam
Reply 0
Aug 10, 2003 | 11:54 PM
bump... -1.5 all around... but arent there more settings for alignment than just 1 thing?
Reply 0
Aug 12, 2003 | 11:44 AM
I tend to like a tad of toe out on front, but it all depends what you use the car for. Not sure what else is adjustable on the car from the factory.
Reply 0
Subscribe
