uneven lowered?
Ok i do not know whats wrong with my car. i thought it was my old 8 struts so i bought a evo9 stock struts. my rear right side is lower then the rear left. my front left side is higher then my front right. wtf is wrong?! do i need corner balancing?
bought it use, there was an inncident where the car was almost ram into by an old lady. so it spuned out and hit a center divider, breaking the 2 right rims. replaced the hud bearing, upper control arm.
maybe you have the springs misplaces possibly one front spring in the front and a rear on the other front side and the rear might be the same situation a front spring in the rear and a rear spring on the other rear side think about it.
correct me if i am wrong, but i believe the front springs will never fit the rear, nor the rear ever fit the front. the front springs are about 5-6inchs wide and the rear are only 3-4 inches wide. front springs have less coils than the rear also. highly unlikely scenerio.
How did you take your measurments? You should measure the distance from the frame to the ground at the four side jacking points. This will indicate how "off" it may be. If you are measuring wheel gap that doesn't really indicate anything.
did you ever figure this out?
Same thing on mine. OEM Bilstein MR suspension wit Swift Spec-R springs. What was the outcome?
Deano_Engineer_
Nov 7, 2016 04:31 PM
WTB[Northeast]: 1 Evo 8/9 MR Bilstein rear strut (1 of mine is lower than the other. Different part?)
Deano_Engineer_
Nov 7, 2016 03:59 PM
ticaaal70
Mar 18, 2016 12:20 AM
MetalMoshpit
Mar 17, 2016 06:23 AM
