which springs?
which springs?
After 45k on my stock springs.... my car does not feel like the evoIX i first had.. i want to get some better springs that will make my car handle better than stock. and i want to lower the car with those springs
question:
need help on springs that will lower the car and will make it handle better???
evoM please help..
... and yes.. i have tried SEARCHING....
question:
evoM please help..
If you REALLY searched, you should have found countless threads about Swift Springs being the most popular springs to use. Swift, GTWorx, RobiSpec and Works are four brands that stick out. Avoid Tein.
well if you car dosent feel the same its pob not the springs, most likely the shocks are gone. and some lousey lowering springs will not fix this and most likely make it ride worse.
try some inexpensive coilovers like STANCE,
If you don't track the car, coil-overs are expensive overkill for the street. Evo's are already amazing cars. Don't waste money on coil-overs if you're just going to be doing an occasional spirited run on the street. In my opinion, it's not worth it. If you do, however, take the car to the track often, by all means go for it. I still think it's best to learn how to outdrive the car before you get to the point where the car is beyond your limits. But, that's just me, I guess.
Check the struts and shocks for being blown. If they're blown, MR Bilsteins and Swift springs are a great combo for the street. If they're not, You can just throw on some Swifts, OR just go for the Bilsteins anyway.
Swifts will lower the car 1.4F, 0.8R
This might help you out
And I just finished writing it.
https://www.evolutionm.net/forums/sh...d.php?t=337211
And I just finished writing it. https://www.evolutionm.net/forums/sh...d.php?t=337211
I was about to post the link for your thread here.
