Missing front cross bars... advice?
Ok so in a nutshell managed to take my car to a friends shop so we could easily install the buscher TBE. After lifting the car and starting on the exhaust I noticed that BOTH my front cross bars are not there, looks like the previous owner removed them for god knows what reason. Kinda pisses me off, especially the fact that I did not even notice =/.
So now I'm looking to try to get something to replace them. I figured I'd call the dealer and see how much the stock ones were for a quick fix, yeah screw that... lol. So I was wondering what people recommend. I had check out the Works Croxx Plate II http://www.worksevo.com/store/produc...products_id=39 but I was curious what other replacments were out there that people felt were an improvement over stock and that would help stiffen the front suspension for autox.
Gonna do some poking around the forums and see what I can find but figured I'd ask as well. So any advice would be highly appreciated =). Thanks for looking!
I'm pretty sure there is another set of holes there, I just never paid any attention to it since there just wasn't a bar there...............................Well this just kind of blows my mind.
Theres really no upgrade though.... its just a bar. The most popular is the cusco type 2 as it is a pretty color blue .... too bad its not visible unless you flip your car over!
Go on ebay and do a quick search for "EVO BRACE" and you will find low cost replacements.
http://www.store.rmrproducts.com/detail.aspx?ID=3
Product Name: RMR Lower K Brace
Price: $176.45
Description: The RMR Lower Control Arm Brace is a replacement for the 2 weak factory bars that spread across the front lower sub frame. Mitsubishi put braces there to help with handling under acceleration as the sub frame tends to spread. Our brace is stronger then the factory units giving more control and less chassis/sub frame. flex. Also, when installing any aftermarket down pipe, the removal of the factory units is a must. Our brace allows room for the larger aftermarket down pipes.
Price: $176.45
Price: $176.45
Price: $176.45
Josh
Well after looking at the choices I settled on the cusco type 2. I was going to go for the carbing 6 point but I found out it places me out of STU class since it does not use the "original mounting holes" and uses an additional 2 holes. Technically this also eliminated the GTSpec bar and the K brace.
I was going to go with the K brace but what I did not like about it was the bend in it that accommodated the down pipe. Then of course finding one in stock became an issue.
So in the end I went with the Cusco Type 2 and I'll see how it feels this weekend if all goes well =).
Jamie@WORKS
Lancer Ralliart Vendor Classifieds
40
Oct 14, 2005 02:28 PM
