Another steering wheel vibrations thread...
So when I press my brakes, my steering wheel will vibrate, BUT it will only vibrate until i de-accelerate to 30mph, from 30-0 it will stop. I had Hawk HPS pads plus rotor pro rotors installed less then 8 months ago, is this a balancing issue?
Take your rotors to a machine shop and have them turned, then use a torque wrench and tighten wheel lugs with factory torque specs.
Nope, can't see it with the eye. Mine are a bit warpy myself. Kinda sucks. Do you notice that when they get warmer its not as bad? Or is it exactly the same after a good cruise?
No, my pads don't make noise very much at all, it did this one time a week or so ago, but that was the first and only time I've heard it.
I believe the vibrations get worse/appear after the car has been driven a while and then they stay pretty much.
Why do we need "Another steering wheel vibrations thread..." Search button is at the top of every single Evom page, please use it.
Read and read some more guys. Rotors can warp but it's very very rare.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml stoptech white paper, they know what they're talking about
https://www.evolutionm.net/forums/sh...ad.php?t=81487 evom sticky "over 4 years old"
Mine too does this, but only when the brakes are cold. If I get them warmed up a bit (drag the brakes) it goes away. I don't think that this is a huge problem unless it doesn't go away.
Stock pads and rotors.
