evo shakes?
Old Jul 20, 2008 | 07:18 AM
cfdfireman1's Avatar
Rotate the tires fist it's a DIY if that doesn't work have the tires balanced.
Old Jul 27, 2008 | 05:54 PM
bbenavitz's Avatar
If you feel any pulsing at all while braking then your steering shake is most likely the rotors being warped which will shake the steering wheel.
Old Jul 29, 2008 | 06:11 AM
EVOlutioner's Avatar
Is there any easy way to fix warped rotors without replacing them? Cause I think that is the problem with my car.It shakes a little at speeds between 60-70 then goes away again but when breaking even from 30-0 the steering wheel shakes like a son of a b!tch...
Old Jul 29, 2008 | 02:50 PM
s2000sc's Avatar
If you can feel shaking/vibration through the steering wheel even when not braking, you may have front wheels which are bent or out of round. The shaking will be more noticeable at freeway speeds. I had an E36 M3, and the notoriously soft OEM wheels were easily damaged by pot holes resulting in the annoying vibrations.
skyseer
17
Jun 29, 2025 10:02 AM
idiaroi
Jun 8, 2016 07:27 PM
anjapower
50
Feb 15, 2015 04:39 PM
OctaneX2
Toronto Lancer Club
Mar 22, 2012 02:14 PM
Charles1
Lancer Troubleshooting
12
Apr 11, 2003 04:02 PM
