Megan coilover springs
I think the OP means the springs that come on their coil-overs.
Swifts makes metric springs for coil-overs. However, you really need to know valving/susp characteristics (aka data) to properly spring a coil-over. I guaranty Megan does not have this information.
(I had Tracks and was going to re-spring them, which is how I found out about Swifts...ended up ditching the Tracks and running their Sports on HDs)
I guess I am wierd or can't drive. I have run the Track (12k/10k) for about 9 months now and over 15k miles and they work great for me. On the track I run just a touch more dampening in the rear than front and the car is very stable consistant, and almost netruel handling wise. A snap of the wheel brings back end out and throttle keeps it where you want it. The only other suspension mod on the car is Perrins RSW with hard mounts.
yeah megan sells springs for both track and street version. i have the track version and may just buy the street version springs. i also have the metric spring specs but i'd have to get that for you later if you rather use a different manufacterer.
Bump - Has anyone tried this?
Anyone know if the damper valving is the same for the street and track megan coilovers?
Are the spring dimensions (length and ID) the same front and rear, is it possible to just swap the stock springs ie: from 12/10 F/R to 10/12 F/R?
I'd like to get some experience with coilovers, and don't want to jump right into a $3000 set.
