vibration
Old Dec 29, 2008 | 08:32 AM
Draven83's Avatar
vibration
So after driving to Baltimore yesterday going about 75 i started to feel a really strong vibration in my steering wheel. But it only happens when i go above 65 mph. however when i go around a turn it stops. Then when i straighten out it starts up again. Any clues?
Chris
Old Dec 29, 2008 | 08:35 AM
Smike's Avatar
Check lug nuts for proper torquing and make sure you didn't loose a wheel weight.
Old Dec 29, 2008 | 10:03 AM
JakeTheVIII's Avatar
Yea what Smikeevo said, I had a wheel come loose on me one time from Discount Tire. If you havent had the car aligned in a while, do that.
Old Dec 29, 2008 | 10:26 AM
Draven83's Avatar
i had it aligned a year ago when i got new tires and also i just rotated. so i guess the tourqeing makes sense.
Old Dec 29, 2008 | 10:38 AM
biggie5252's Avatar
I had a similar vibration (above 65, lessened around curves) and it turned out to be a bad tire.
Old Dec 29, 2008 | 10:49 AM
BlackTypeS's Avatar
check tires, lug nuts, and make sure you didnt lose a wheel weight...does the vibration also happen when you brake? if so it could be warped rotors
Old Dec 29, 2008 | 11:25 AM
Draven83's Avatar
no. i have new rotors. it stops when i brake
Old Dec 29, 2008 | 12:20 PM
blaze9489's Avatar
Did you check everything else people mentioned? When was the last alignment also?
Old Dec 29, 2008 | 12:23 PM
Draven83's Avatar
i was aligned in feb when i bought new tires. i dont know how to tell if i am balanced or not.
Old Dec 29, 2008 | 12:32 PM
WhiteEvo05's Avatar
Been down this road before...checked balance, alignment, wheel bearings, rotor run out, control arm bushings, ball joints, tie rod ends. In the end it turned out to be strut mounts. At about 68-70-ish mph the steering wheel did the shimmy then subsided at about 85-ish. No shimmy above or below that range.
This was the first thing Robert (Robi) Fuller of Robispec told me...I should've listened. He explained that below a certain speed the rubber in the strut bearing mount was able to damp the harmonic vibration, but within a certain range it wasn't able to because the rubber was fatigued (worn out). I replaced mine with RalliArt Group N bushings...a little stiffer than stock, but not like pillow *****.
If you already have pillow ball mounts, I have no suggestions other than what's in the list I rattled off earlier.
YMMV.
Old Dec 29, 2008 | 12:41 PM
Draven83's Avatar
thats exactly whats happening
Old Dec 29, 2008 | 07:47 PM
BKaulitz's Avatar
glad u found the problem
Old Dec 29, 2008 | 07:53 PM
gsr0801's Avatar
I had that and turn out one of my front tire was chewed up on the inside.
