Camber/Caster Plate for stock struts
Old Feb 7, 2009 | 03:55 AM
Maximum404's Avatar
Veteran: Navy
I have been looking around and have not found a camber/caster plate that works with the stock suspension. The whiteline piece is nice, but doesn't work as far as I can tell. I need to get my caster within spec and I can't do that with what I have. Thanks for the help!
Old Feb 7, 2009 | 09:04 AM
Smike's Avatar
You should not have issue with caster on the OE. The caster is set and cannot be changed...should be around 3*54'
Old Feb 7, 2009 | 10:59 AM
o-townFLA's Avatar
Look for K-Mac camber/caster plates. They work with OEM suspension and aftermarket.
Plus some of the fastest Evo's run 'em...!
Old Feb 7, 2009 | 12:21 PM
Maximum404's Avatar
Veteran: Navy
Thanks for the tip! My caster is .7 degrees off on each side (FR/FL), but the rear is fine. I love my camber setup as it is (Thanks Performance Wheel and Tire Cheasapeake, VA!) and just want to get the caster in spec.
Old Feb 7, 2009 | 12:28 PM
Maximum404's Avatar
Veteran: Navy
Wow, what's with all the aussie suspension guys? A little pricy...might be more worth it to go with a set of coilovers with the adjustment ability already there.
Old Feb 7, 2009 | 12:57 PM
PPI's Avatar
PPI
I have used Tein camber plates with stock suspension in the past....for more camber. They worked fine.
Old Feb 7, 2009 | 01:57 PM
GTWORX.com's Avatar
You could also get regular cuscos and rotate them for extra caster.
- Andrew
Old Feb 8, 2009 | 12:45 PM
RaNGVR-4's Avatar
if your caster is out of spec you may have a bent control arm.
Old Feb 8, 2009 | 01:33 PM
SICK9's Avatar
I have the cusco camber plates on the oem bilsteins with tein Htech springs and they work great.
I'm pretty sure whiteline makes a camber plate that will also work with the oem setup.
Next week my coilovers will be here and I wont need the camber plates or oem struts etc....
Old Feb 8, 2009 | 01:39 PM
MR Turco's Avatar
I also run the teins, looks great and work fine.
Old Feb 9, 2009 | 07:15 PM
Jeff_Jeske's Avatar
This is true... you shouldn't be having a caster problem.
Also if you go with camber plates on the stock struts and springs they tend to raise the front of the car about a half an inch. If you are lowered you probably won't notice. If not it will look more like a truck.
Old Feb 10, 2009 | 03:53 PM
Maximum404's Avatar
Veteran: Navy
The control arm is fine as are the ball joints (two most common caster problems). The type of caster/camber plate installed will determine the height that the car is raised. Although most to raise the car a bit. I went back in today for a checkup and the camber is better and so is the caster (in Mitsu spec) after the car has settled again. Andrew, thanks for the tip, I'll look into that if I get some unwanted tread wear patterns.
Old Feb 11, 2009 | 10:05 PM
mr.green's Avatar
I use tein's as well and have had great luck with them.
Old Feb 20, 2009 | 10:49 PM
IceHawk's Avatar
I think Vorshlag Motorsports might make some that will work with stock stuff. I have heard their plates are amazing
LV///R
81
Mar 23, 2015 07:40 PM
KevinD
Jun 30, 2014 04:26 AM
xspsi4
41
Aug 12, 2013 01:39 PM
saxon
12
Apr 25, 2011 06:16 PM
MrAWD
Feb 28, 2008 12:11 PM
