Choosing coilover spring rates for your EVO
It's gonna depend on a few things, including the amount of droop travel and the tires you're using. And if you have a stock front sway. Many set-ups will lift the tire.
- drew
- drew
I've seen pictures of Andy's first autocross EVO back in 2004 running in AStock class. On stock suspension that thing would lift the inside rear about 10" off the ground, so IMHO it is not a problem with the rear end not having enough droop or the rear sway bar being too stiff. I feel the problem is the front end not being stiff enough and the outside front corner diving (as well as the whole car having too much body roll), thus pulling up the inside rear. My thoughts on keeping the rear down are to lower the CG and/or stiffen the front.
Awesome thread guys. Didn't know there was so many nerds (good thing) that could help out in here. I went from knowing apparently next to nothing to quite a bit in my eyes just through this one thread (19 pages of solid reading though... haha)
This should be a sticky for sure. It should almost be posted as a new member requirement.
Hi, just wonder will it be advisable to run a spring rate of front 6kg & rear 10kg?
The reason is ive found a 10kg rear spring at the moment as ive planned for a stiffer springs upgrade for my Tein HA coilover on my Evo 4.
Thanks
Thanks
If you absolutely must do that 6k/10k, I would have a bigger front sway bar (well I would have that anyways
I have set of hyperco 8" long, 2.5" ID springs in 450 and 550 (8k and 10k) Ill be selling reasonably cheap ($100/pair) if that would work for you. 6k/10k is to great of a split in balance. Either do 6k/8k or 8k/10k.
) and remove the rear bar.
Jalan Gasing Indah 46000,
Petaling Jaya, Selangor, Malaysia.
Lastly will it fit my Tein HA model?
Thanks
James
This thread is excellent. After four sets of aftermarket springs on both stock struts and coilovers, I'm now running 450lb F/500lb R on JRZ RS coilovers with a Quaife front diff and Shep 12 plate rear on 265/35/18 Direzza, and so far this is as close as I've ever come to handling nirvana in an Evo on street tires!
I simply cannot stress enough the importance of having quality dampers, the right tires, and a proper alignment( preferably corner balanced) to make the most of any suspension.
It's interesting that a lot of coilover manufacturers, including high end ones like Ohlins, use a heavier front spring than rear (eg. 10 / 8). You would think that they would have taken into account the rear end of the evo and designed their rates accordingly?
