Spring Install help, this okay?
Old Feb 24, 2009 | 07:15 PM
ronitlancer's Avatar
So I just installed my front springs, (swift) and I went through the guide on evomoto.com
The question I have is, on both of them I was told to line up the spring into the "grooves" the old spring set in the rubber. If its off a little bit does it matter? On my top groove the plastic came off... So I totally lost how it was setup before.
Let me know if its something I should make sure is done 100% or what I am saying doesnt sound like a big deal.
EDIT: New quesiton, I replaced my rear spring today and I don't know if this is known or not but the inside of the strut nut has a small layer of silicone (im assuming to help keep it on) and from the douchebag previous owner who put a strut bar he totally messed up the top of my strut bolt so I had to WD40 the **** out of my nut and it ended up deteriorated my silicone layer, is this super important, aka should I go get a new nut or no
Naor
Old Feb 24, 2009 | 07:19 PM
shupadupa's Avatar
I don't think that is a big deal at all...you may hear some "clunking" from the springs shifting.
Old Feb 24, 2009 | 07:20 PM
Octane Blue's Avatar
what do you mean by "its off a little bit?" how is it "off"?
Old Feb 24, 2009 | 07:56 PM
I'd say the bottom is probably half a finger off, maybe less. And the top I really have no way of knowing because the "indent" in the rubber is totally not where it used to be. So on the top I don't know but the top cover only sits ONE way doesnt it? So that can't be too off.
Smike's Avatar
The rubber should move. You can take it out of the top mount and adjust it.
Old Feb 24, 2009 | 08:00 PM
Originally Posted by smikeevo
the rubber should move. You can take it out of the top mount and adjust it.
+1
Old Feb 24, 2009 | 08:50 PM
Yes I know, but unlike on the bottom of the strut there is no specific fit of the rubber. It can go in any way cause its just simple round.
Old Feb 24, 2009 | 09:58 PM
bump
Old Feb 25, 2009 | 03:39 AM
Smike's Avatar
Bottom strut you line up with the spring. Top mount can be turned and adjusted to fit the new spring.
Old Feb 25, 2009 | 03:51 AM
OhsixIXBish's Avatar
There 2 holes in the top and bottom plate. Theres 3 on the bottom i believe its the middle hole. Ans theres one on top the same size u gotta look close b.c its not much bigger than the other holes make sure these 2 holes are lined up when u get the spring set it in place. If not the spring will rotate when u turn the wheel and make a poping noise. But It should be noticeable where the spring sat inside the strut plates. Good Luck with your install!
Old Feb 25, 2009 | 09:29 AM
Only 1 hole on my strut (MR). I didnt have anything long enough to go through the holes at the place I did my passenger side so i dunno but my driver side definitely fit through the holes so im sure that one is fine.
Smike, I know it can be adjusted a little and thats somewhat of the problem, the rubber fell out and the rubber has no specific way of fitting back onto the cover. Do you get what im saying? So the "indent" on the rubber is meaningless because the rubber can fit any which way back onto the top cover. Meaning all I can do is poke through that hole I guess but I didnt have anything to poke through.
Old Feb 25, 2009 | 09:55 AM
Smike's Avatar
The rubber can be turned to fit the new ending on the Swift spring. Then attach and line up the top mount holes, then tighten it down.
Old Feb 26, 2009 | 12:03 AM
The rubber will fit the spring no matter how its on it..... Its simply round, how could it not fit lol. I guess I just need to take my wheel off and just get under the car and see if the holes are lined up enough or not.
New quesiton, I replaced my rear spring today and I don't know if this is known or not but the inside of the strut nut has a small layer of silicone (im assuming to help keep it on) and from the douchebag previous owner who put a strut bar he totally messed up the top of my strut bolt so I had to WD40 the **** out of my nut and it ended up deteriorated my silicone layer, is this super important, aka should I go get a new nut or no?
Thanks,
Naor
Old Feb 26, 2009 | 09:49 AM
bump, another question added to OP.
Old Feb 26, 2009 | 02:23 PM
bump for new nut?
stockley1234
30
Dec 23, 2013 03:44 PM
EVO8emUp
May 7, 2013 08:47 AM
blkmkIII
44
Oct 14, 2011 02:12 PM
undercoverpope
20
Jul 20, 2011 10:54 AM
groove304
For Sale - Cars For Sale
29
May 1, 2008 10:53 AM
