Tire Question
Old Feb 25, 2009 | 06:36 AM
binky's Avatar
Question Tire Question
Hey Guys-
I am going to be buying some new tires soon and I have a few questions.
The stock tires are 235/45/17. Can I (should I) run 245/45/17 tires on the stock rims? Will they rub?
I am currently looking at two tires. Toyo R1R's and the Nitto Nt05's. Any preference as to which one I should pick over the other? Any other tire suggestions? The Evo is my weekend warrior so I don't drive it all the time.
Thanks for any input
-Bink
Old Feb 25, 2009 | 06:53 AM
Smike's Avatar
Please search and read on this issue. It has been covered - a lot.
245/45/17 will work fine on the OE rim. Depending on the tire 255/40/17 also works.
https://www.evolutionm.net/forums/6721786-post37.html
Old Feb 25, 2009 | 06:57 AM
binky's Avatar
Thanks for the reply and link. Do you have any personal tire manufacturer suggestions?
-Bink
Old Feb 25, 2009 | 07:08 AM
Smike's Avatar
Depends on the usage. For what you have mentioned - TR1R's or NT05's are good weekend warrior tires. 2 others are the Dunlop Z1 Star Spec's and B'stone RE01R's (sale on those right now). The Z1* have better heat up and grip - I raced last season on the Z1 and Z1* - great tire.
Old Feb 25, 2009 | 07:11 AM
binky's Avatar
Yes, the Evo is my weekend warrior
Awesome, thanks for the input, I'll check those tires out as well.
Thank you!
-Bink
Old Feb 25, 2009 | 07:12 AM
vgknight's Avatar
he is right.... havent had any problems with my 245 45 17
and a buddy is runnin 255 40 17 on his evo
Old Feb 25, 2009 | 07:16 AM
binky's Avatar
Cool Thanks dude !
-Bink
Old Feb 25, 2009 | 08:20 AM
Fireball's Avatar
Although a GREAT aftermarket size for the Evo is 245/40R17. Go a little shorter, because if you go up to a 245, you'll actually have a slightly taller tire than the factory, which will adversely affect handling performance.
Old Feb 25, 2009 | 08:23 AM
binky's Avatar
How short would you recommend?
-Bink
Old Feb 25, 2009 | 08:28 AM
CantStopSpinin's Avatar
are you lowered at all? didnt see it mentioned.
i suggest if not 245/40/17.
Old Feb 25, 2009 | 08:52 AM
jamevo8's Avatar
stay with 235/45/17 I went with 245/40/17 and went back to 235/45/17 better ride
Old Feb 25, 2009 | 10:43 AM
binky's Avatar
I am not lowered at all.
After looking online i used http://www.1010tires.com/tiresizecalculator.asp to figure out the differences between the tire sizes. Still haven't decided which to go with, I'm still reading and waiting to hear opinions from people
-Bink
Old Feb 26, 2009 | 10:11 AM
evokid511's Avatar
sorry to thread jack you but if i were to lower my evo with some coilovers... what sould be a good size... im rubbing a lil already on stock height with 245/45/17
Old Mar 27, 2009 | 09:44 AM
286bhp's Avatar
I am getting mixed messages about rubbing with 245/45/17 on a stock MR suspension and stock MR 17" BBS wheels.
evokid511 and the tire sticky say that I will get rubbing.
vgknight and SmikeEvo say rubbing will not be an issue.
What should I take away from this? Rubbing may be an issue?
Old Mar 27, 2009 | 10:29 AM
deoreo's Avatar
286bph, I can give you a data point on my set up.
I'm currently running RT615 tires in the 245/45/17 size on 17x8 +29 wheels with stock MR suspension.
Stock offset is +38 So the +29 I'm running pushes the wheels slightly towards the outside of the car
I don't have any rubbing at all.
