Trouble Removing Bolt on Rear Shocks?
Has anyone encountered this problem? I was trying to get that top bolt off but turning that bolt seems to spin the entire metal piece of the shock..
Any solutions?
Any solutions?
You have to use a crescent wrench to hold the shaft while breaking it loose with a 17mm open ended wrench. If you don't it will keep on rotating.
Courtesy of EvoMoto
http://evomoto.com/tech_info.php?tPa...96d92818e29d60
See step #16
Courtesy of EvoMoto
See step #16
Thanks for the help. Finally done! After we got the struts back on, they started spinning again.. so I had to get them to use the impact gun to tighten it up. It just wouldnt tighten otherwise.
Suspension is great, the fronts randomly creak once in a while when I'm turning the wheel to full lock.. Not sure what that's all about, but everythin seems to be in running order
JDMevoBOOST
Nov 1, 2015 03:44 AM
urbanknight
37
Dec 26, 2011 01:35 PM
Pick_a_Fro
23
Mar 20, 2006 12:41 PM
