For those with front end "clunking"
Yeah that's what mine was... I also noticed because the right side bottomed out when I went into pot holes... roads in Boston are f!@#$% up
You dodge one pot hole to land in another one... and forget taking it up with the city. It's only being placed on top of a tower full of other pending cases
I have a similar clunk except it comes from beneath my feet, and has gotten progessively worse. Seems like weather also plays a part in it. What the hell could it be? It's definitely doesn't sound like the strut, because it's coming from directly underneath, possibly toward the center of the car. Swaybar possibly? Also my friend ran over a nasty curb, and did damage to the fender/wheel/knuckle (passenger side) a while ago. Is it possible he could've knocked something loose down there? Weird thing is first time I noticed it was after I was dynoed.
i had some clunking also on the front , the wierd part is that when i lowered my car it dissapeared. the only thing i can thing of is that there was some loose parts some where in the struts. i actually thought it was my down pipe coz i started hearing it just right after i installed it. i started adding more washers to my brace to give it more clearance to no avail.
My noise comes and goes. There was a post I found from someone having the bottom rubber part where the spring sits trimmed, because it traps rocks in there. It causes the spring to bind up from the rocks being in the way. Here is where I found it along with a TON of more info. Hope this helps. https://www.evolutionm.net/forums/ev...-noise-11.html
thats what happened to me as well this winter , but I was making squeaking noises. I cleaned out the spring and problem solved. This was for a squaking noise. The biggest culprit would be ball joints (OEM) if you put in aftermarket springs it puts more stress ont he OEM balljoints.
Well my Evo 9 has 44klms/26miles on it...coil overs...and does the same thing...sounds like I dropped a wrench in behind the engine and its knocking against the body...mainly does it..well its more noticable at low speeds on roads with the samllest bumps...feels suspension related as it does it as the suspension move....I replaced sway bar end links with Whitlelines..its just come back after being gone for 2 weeks..worse than ever...has me stumped...sometimes..last time...was left side (passenger in OZ)..now its back drivers side...wher it originally started...next step fo me is sway bay rubbers..ordered...that looks like a great job...NOT!...I am usually good at getting this stuff but I am tearing my hair out....my tuner was in the car doing a power run with me 2 days ago and he was aghast...he drives a Nissan GTR...he said it sounds like the front end is going to drop out..Dealer wants to do the ears thing...at $110 an hour...and I am not confident they will find it anyway...I am seriously at my wits end with it....might just unload it..nice car but my WRX or R32 GTR never gave me this grief...
ctrenks
71
Oct 7, 2025 02:19 PM
purpledranktown
Jan 6, 2016 07:19 PM
cmross13
Apr 22, 2014 09:36 PM
m3typer
Jun 24, 2012 06:15 PM
Evo D
42
Jun 16, 2010 09:16 PM
