Another Alignment Question!
Old Mar 24, 2009 | 08:35 PM
Smike's Avatar
Contact Andrew @ GTWorx.com -- I know they have a few more then the selection below:
http://www.gtworx.com/catalog/advanc...+plate&x=0&y=0
Or
RobiSpec
They carry the Kmac's
https://www.evolutionm.net/forums/ev...er-plates.html
Old Mar 24, 2009 | 08:38 PM
Meevo's Avatar
Originally Posted by rolly1818
so caster plates should be an easy fix for this?
sorry for the thread hijack.
when they changed my camber it was as simple as turning the camber bolts. it is really DIY but you need the machine to make sure your dialed in to your specification. or if u want max camber turn the bolts so the lobe on the bolt reflects this.
Yes, but I'm wondering where/why the spindle holes they had such problems with were.. problematic.
Old Mar 24, 2009 | 08:50 PM
Jeff_Jeske's Avatar
I would walk away from that shop and dispute the charge. They don't know WTF they are doing.
These cars are a joke to align. There's not much you can do really. If you are lowered you should easily be able to get the alignment you want.
Old Mar 24, 2009 | 08:52 PM
Meevo's Avatar
how would I go about disputing the charge? in any case, at the moment I have a 6 month 6000 mile "warranty" on the alignment
Old Mar 24, 2009 | 08:55 PM
MJ23FE's Avatar
Today I went to Euro-Tire in Fairfield, NJ and had my car aligned since I had my GTWorx springs installed this past Sunday.
Here's my sheet. I asked for -1.8° Front & -1.25° Rear with 0° Toe all around.
Whatcha think, smike?
-Jalal
Old Mar 24, 2009 | 09:09 PM
Smike's Avatar
Old Mar 24, 2009 | 09:31 PM
Meevo's Avatar
dang it.. what's wrong with tires plus
Old Mar 24, 2009 | 10:31 PM
Meevo's Avatar
-Jalal
you didnnt have to do any spindle grinding bs? what even is that??
Old Mar 25, 2009 | 09:23 AM
MJ23FE's Avatar
All I did was turn the bolt so that the arrow is pointing out. I dropped it off and voilà. I got what you see.
-Jalal
Old Mar 25, 2009 | 10:35 AM
GTWORX.com's Avatar
That looks great Jalal.
Meevo....do you know which direction the camber bolt arrows are facing? You can reach your hand around with camera + flash and take a pic.
IMO there are more incompetent alignment shops than there are competent ones.
- Andrew
Old Mar 25, 2009 | 11:24 AM
Meevo's Avatar
yeah...
UPDATE::::
- I went into the shop today, with the papers showing instructions that were attached in this thread - I showed them to manager, as well as a picture of the bolt
- He said that that's not what my bolt looked like, and that my bolts were not eccentric -
- I thought that maybe my new struts had come with new bolts, and that I had just forgotten, and used new bolts
- I APOLOGIZED to him for my mistake, and went home to check
- When I checked, I saw that I did NOT have new bolts, and the bolts on my struts were indeed the stock bolts
- I called them, and said that perhaps when I put the struts in I put the eccentric bolt on the bottom, and asked him if he had looked at the bottom bolt
- The manager then replied that actually, he did not look at either bolts!! He then went on to say that if I wanted, he would align my car back to factory, but he will no longer adjust the vehicle alignment to the specs I had asked.
- I asked him why not, and he said that the car was a headache ever since they started working on it, and basically that they don't want to deal with it anymore.
- I thanked him, hung up, called Tires Plus corporate and logged a formal complaint
I guess I will have to go ahead and pay another shop to do my alignment
Old Mar 25, 2009 | 11:51 AM
GTWORX.com's Avatar
Wow....that's really lame. So he said you that your bolts were not eccentric, then admitted to not even looking at them. LAME!
You should get your money back.
Anyone know of a good shop in IL for alignments?
- Andrew
Old Mar 25, 2009 | 12:01 PM
Smike's Avatar
I think AMS is doing them in-house now.
Old Mar 25, 2009 | 01:19 PM
Meevo's Avatar
- Andrew
Indeed -
After I logged the complaint with corporate Tires Plus, the shop manager called me back to say I could have my money back - So I'll go to the shop tomorrow and do it. They also said for how "complex" my request was I should be asking a performance shop in chicago or wherever and having them do it
but I actually contacted Good Year, they knew exactly what I was talking about with everything, and when I mentioned that to him he replied that the alignment guy there was really good..
Old Mar 25, 2009 | 01:21 PM
Shadowpriest's Avatar
yeah...
UPDATE::::
This is why I pay for things via my credit card. If you pay for a service and said service is not performed getting your money back is as easy as filing a complaint with the cc company (making sure you first try alternate routes such as letting the shop or whatever correct their mistakes). I've done this numerous times in the past with much success.
