Front sway bar makes a big difference!
Old Mar 29, 2009 | 06:46 PM
18bora's Avatar
For the longest time I didn’t believe a front sway bar was necessary. Part of the reason it’s such a pain to install. So, instead of going through the hassle of installing a new one, I decided to modify the stock bar using home made endlinks. After all said and done, I took the car for a ride and it made a noticeable difference. Keep in mind this is in addition to 25mm RSB and otherwise stock suspension. Besides being much flatter around corners, to my surprise, steering response (turn in) is much crispier and easy to turn in, no need to manhandle the car into the corner anymore. Overall, it’s well worth it.
The whole process took about 2 hours.
1. Put the front on jack stands.
2. Remove both front wheels.
3. Remove stock endlinks and bracket.
4. Support the sway bar with a block of wood, to give you clearance when drilling.
5. Mark the spot (about ¾” in from the stock hole) and use a center punch.
6. Keep the brake lines away from the drill bit.
7. Start with a small bit, and then move on to the bigger one.
8. Install the new endlinks.
Home made endlinks: http://www.cs.unm.edu/~donour/cars/evo_endlinks/
Original idea: https://www.evolutionm.net/forums/ev...djustable.html
Drilling wasn’t as bad as they made it sound in the other thread: http://www.youtube.com/watch?v=OBGbY...e=channel_page
Old Mar 29, 2009 | 06:53 PM
Smike's Avatar
I <3 my front sway bar.
Old Mar 29, 2009 | 07:04 PM
krisdlm's Avatar
looks good bora!
Old Mar 29, 2009 | 07:06 PM
xspsi4's Avatar
Stickey this?
I may just do this as opposed to changing my front swaybar although I already bought the set.
What rear bar are you using?
Old Mar 29, 2009 | 07:09 PM
Evoryder's Avatar
nice
Old Mar 29, 2009 | 07:10 PM
idriveanevo's Avatar
why did you need to drill new holes?
Old Mar 29, 2009 | 07:12 PM
xspsi4's Avatar
Also off that list, What parts are needed just for the front?
I believe the list is for 4 correct?
I may order from mcmaster tuesday and try this.
Old Mar 29, 2009 | 07:42 PM
18bora's Avatar
Originally Posted by xspsi4
Stickey this?
I have Perrin 25mm RSB
Old Mar 29, 2009 | 07:50 PM
18bora's Avatar
2458K141 CARBON-FIBER RACE BALL JOINT ROD END 3/8"-24 RH MALE SHANK 2
2458K341 CARBON-FIBER RACE BALL JOINT ROD END 3/8"-24 RH FEMALE SHANK 2
98017A199 18-8 STAINLESS STEEL AN 960 FLAT WASHER 3/8"L SZ,NO. C616L, .390"ID,.625"OD,.029"-.035"THK
97135A235 GRADE 8 HEX NYLON-INSERT LOCKNUT ZNC-YELLOW PLTD, 3/8"-24 SCREW SZ, 9/16"W, 29/64"H 1
91286A252 GRADE 8 COATED ALLOY STEEL HEX HEAD CAP SCREW 3/8"-24 THREAD, 2" LENGTH 1 10.17 10.17
Pegasus Racing Parts:
3068-06 3/8 inch Rod End Retaining Washer 4
AN316-6-R AN316 Jam Nut, 3/8-24 Right Hand 2
You will also need the drill bits, and I had to use a couple of 1/2" nuts (as spacers).
Old Mar 29, 2009 | 08:03 PM
donour's Avatar
Originally Posted by 18bora
2]
You don't actually need the jam nuts for the front. If you think about how they mount, they can't rotate/loosen without being unbolted. They're only $0.40 though...
d
Old Mar 29, 2009 | 08:32 PM
MitsuJDM's Avatar
I did this last fall. I took me 2 days. It was absolutly horrible, haha. I used TONS of oil, and still burned through 4 drill bits
After I finally got it done, I did notice a differance in turn-in and the car does corner SLIGHTLY flatter, which was my #1 goal. In conjuction I use a Whiteline 24mm RSB on the middle setting. Softest setting I didn't notice a difference. Stiffest setting I was getting WAY too much inner rear wheel lift. The middle setting is juuuuuust right
With Swift Sport springs, I find it to be an awesome set-up, although I feel my stock GSR struts may be a little worn from the previous owner S-techs, so I'm trying to gather some money for HD's.
Back on topic, this sway bar mod is great and noticable but I do feel that a REAL front sway bar would be a much better alternative. A good thing to do if you're doing a clutch install. When I do my clutch install sometime down the road, I'm going to buy a sway bar as well
Old Mar 30, 2009 | 01:48 AM
NEVERBROKE's Avatar
cool info
Old Mar 30, 2009 | 04:38 AM
RichC's Avatar
it shortens the bar, or at least the distance between endlinks on each side, in effect making it stiffer.
Looks good though, but I think I'll just wait until I need to do a clutch, then put in a fresh bar and end-links. I wonder what Mitsu would say about warranty if they saw it, LOL.
Old Mar 30, 2009 | 08:11 AM
GTWORX.com's Avatar
If someone ever takes their bar off the car and takes some measurements, i could figure out the effective diameter of the shortened bar to compare it to an aftermarket bar.
- Andrew
Old Mar 30, 2009 | 08:31 AM
Smike's Avatar
I have my stocker up in the attic in OH. I can mark off where the holes are for you and send you that measurement. Do you want as the crow flies (hole to hole) or along the bar?
