ABS light - speed sensor codes all 4 wheels
Old Mar 30, 2009 | 03:51 PM
Driveteam's Avatar
Like the title says -- throwing a code for all four wheel speed sensors thus the ABS light stays on. The fuse is good. Where else should I look?
The car is a 2005 Evo SSL
Thanks
Old Mar 30, 2009 | 07:46 PM
rsboy's Avatar
Have the dealer check the codes. There really is not way to turn it off thru the ecu or anything. I think the dealer has a special scan tool they use for it. Hopefully they can help you and fix it under warranty or something.
Old Mar 30, 2009 | 11:19 PM
Driveteam's Avatar
thanks for the help. I had no idea it was that difficult to solve. We found the codes on our scanner - are you sure only Mitsubishi can solve it?
Old Mar 31, 2009 | 03:12 AM
tougetuned's Avatar
is the light on when you start the car or does come on after you start driving and braking a little? you may need to replace the wheel speed sensors it sounds like, it could be the abs speed ring but it doesnt seem like it, if the abs speed ring had a chipped tooth then your abs would engage under normal braking for a bit then the abs light would come on and then the abs would stop working and it would brake like normal again, but abs would not work
Old Mar 31, 2009 | 06:25 AM
rolly1818's Avatar
Registered User
check ur liquid level, that will throw a code or if one of ur sensors goes bad.
Old Mar 31, 2009 | 11:58 AM
PVD04's Avatar
The ABS light will reset on its own if there is not a problem. That was my experience with my car after I replaced a wheel speed sensor.
Old Mar 31, 2009 | 06:42 PM
rsboy's Avatar
I had a problem with an ABS light constantly on and after researching about it, the only way to fix it was replacing the sensor. I might be wrong about the dealer having the only scan tool for it, but if you are there, you can at least find out what exactly is wrong with the ABS.
It could be sensor issues or the ABS module. Those sensors are freaking pricey so hopefully you can have it sorted out. Good luck!
CottageLifer
Outlander Sport
Apr 20, 2016 06:53 AM
shavkatjon2000
Oct 1, 2014 03:38 AM
REV.olution
Mar 20, 2014 08:45 AM
foxbear2277
12
Dec 3, 2013 03:41 PM
bb4g63
Dec 19, 2012 10:42 PM
