Anti Lock Light keeps coming up!
I'm having the same issue. The steps I'm going to be taking is to closely examining the ABS ring which is on the axle. You have to make sure none of the teeth are bent or missing. One small chip or bent in the rings will cause it to trip the system. I should be looking at mine this weekend.
So an update for those who have the same issue as myself. Both passenger side wheels took a curb hit at 15-20mph. Taking a look at both tone rings I found only the rear to be missing some teeth. I'm replacing the rear axle and hoping that’s the only issue.
I still have the same problem. I was a bit lazy and also busy with school, but now im free and ready to get this over with.
I bought used axle long time ago, thinking it was a chipped off tooth, but after lifting the car, and taking the tire off, I figured that my axle was good, all the rings were just fine. Prior to that, the speed sensor was changed because my friend that works in Nissan dealer told me that was a problem. But NOP, that wasn't it. So, whats next?
I have the same problem, looked at my abs rings and my pass rear has 2 missing teeth, im looking into replacing just the ring since the axle is perfectly fine.. worst case ill weld onto the missing teeth section and grind it down basically forming the teeth again. if no one has replacement axle abs rings then that would be a pretty quick and simple fix as long as you have access to a welder.
