what offset for 18x9 wheels on evo mr
What size tires are you looking to put on the car?
The offset will depend on what your looking to do with the car.
18x9 +29 is the most common done setup with the Advan
18x9.5 +22 sits perfect on the evo.
If you calculate it out. with a 9.5 your sitting at a 241 mm wide rim.
1" = 25.4mm
witha a +22 offset that gives you 98.5mm of lip/concave or 3.88 inches.
You would have to convert and swap in the numbers yet you can see where iam going with this.
a 9" rim is 225mm wide
a 9" rim compaired to a 9.5"
you would take off .25 off each side bringing you to 6.35mm off each side.
etc....etc..
Maybe iam looking into it too much haha..
1" = 25.4mm
etc....etc..
1" = 25.4mm
etc....etc..
1" = 25.4mm
etc....etc..
another concern is that i dont want the profile of the tire to be extremly low.
this car is a daily driver and i live in greece , the roads hear are f**d up, bumpy ,uneven sometimes etc, so i dont want anything working against me,
another concern is , if this makes any sence i dont know if to wide a tire can work against me on the street, i dont track
all i see is a 18x8.5 with a +30 offset. you will be fine with that. As well a 245/35 tire will be perfect.
IF that is the rim your going with. This is the perfect tire combo to go with. Anything bigger will look bulged out. Anything smaller will look retarded and serve no purpose.
the tires i was thinking are dunlop direzza z1 star spec
