how does my alignment look?
Old Jun 12, 2009 | 05:53 PM
idriveanevo's Avatar
i took my evo to get an alignment today and i asked for -1.7 camber up front, 0 toe. -1.4 on the rear with 1/16in. toe.... im on swift springs.
they came up with:
left front, -1.5 camber, 3.5degree caster, -0.01degree toe.
right front, -1.7 camber, 3.2degree caster, -0.04degree toe.
left rear, -1.3 camber, 0.04degree toe
right rear, -1.3 camber, 0.05 degree toe
Old Jun 12, 2009 | 06:02 PM
McLaren F1 2003's Avatar
i think it looks pretty good
Old Jun 12, 2009 | 06:19 PM
prostcj's Avatar
left to right camber is too far out and too much rear camber for the front camber setting but the rest looks fine.
Old Jun 13, 2009 | 12:55 AM
any suggestions? i have lifetime free alignments now so its no big deal!
Old Jun 13, 2009 | 05:08 AM
Smike's Avatar
I think that looks great. There is a +/- when using camber bolts. We cannot nail an exact number. That is within spec.
That is almost exactly the alignment I run.
Old Jun 13, 2009 | 09:19 AM
i was hoping you would chime in! im not sure if its the rear toe, but now it seems if i make a sudden turn at a higher speed, that the rear end keeps moving over for a split second.... any body fealt something like that?
Old Jun 14, 2009 | 05:14 AM
Smike's Avatar
Rotation
What are your tire pressures?
Old Jun 14, 2009 | 10:14 PM
rotation? pressure is at whatever is on the door... its just feels really weird. like i have really tall tired on the back or something
Old Jun 15, 2009 | 06:19 AM
Smike's Avatar
Rotation, aka oversteer. Where you can walk the rear around a bit more to help with tight turning in AX and tracking.
Could be too low of pressure in the rear tires. That might give you that sensation as the tire patch moves. Try 32/32 then go up and down in the rear until you get it to something you like.
Old Jun 15, 2009 | 05:31 PM
xtnct's Avatar
I have the swift spec-r with RCA & camber plates rotated with stock shocks.
I set my front to -2 camber , 0 toe. Caster ended up being -4
Rear I tried to max out and all I got is -1.1 camber with about 1/32 toe in.
The car felt great in the dry & wet at the track. I did not really notice much understeer at all. Initial turn in does feel a little jerky though...need to learn how to smooth out the initial steering input.
Old Jun 16, 2009 | 09:07 AM
why did you toe in the rear, instead of out? you should be able to get alot more camber out of the rear
Old Jun 16, 2009 | 09:45 AM
xtnct's Avatar
Toe: Because I wanted stability under accel & cornering (for the wet & street). Apparently the car toes-out as the car squats and rolls. See Post #7 here: https://www.evolutionm.net/forums/ev...d-toe-out.html & https://www.evolutionm.net/forums/ev...et-racing.html is a good read too.
Camber: Because the shop I went to messed up my alignment on Friday PM, and I was going to track on Monday am. Had to fix alignment on my garage floor Sunday pm and after raising the car 50 times up and down, I just wanted to sides to be equal as I had enough. Doing the rear is a big pain using camber plates & camber level gauge on a regular garage floor especially that changing toe messes up the camber and vice versa. Can't do it as easily as the front where you set camber then just do toe. In back, set camber, then set toe, re-measure, and the camber is messed up due to toe change (or vice versa).
I actually liked these settings... I may not mess with them unless I feel I'd want the car to behave differently.
goofygrin
88
Jul 24, 2022 08:22 PM
kyoo
Nov 21, 2016 08:43 AM
slvrevo
Apr 21, 2006 10:11 PM
Blue_by_u
11
Sep 24, 2004 09:56 PM
