Alinement today
Old Aug 2, 2009 | 12:27 PM
nebevo's Avatar
Wink help help Alinement today
WELL let me start off by saying i ran over a nail, Took it to the local tire shop guy says to close to the side wall, so my tires already need to be replaced anyways, So i say ok all new tires and Alinement please, shop gets to work and then finally gets it on the Alinement rack 15 min later shop says i need to change a bolt that is factory to a fully adjustable bolt to get prefect toe Alinement.
tires i just bought rf falkin 235/45/r17
WTF your telling me that the mitsu put a car out on the market with factory bad aliment bolts so u cant get prefect toe aliment?
on the front and back
car drives straight
my car is compeltey stock nothing changed at all stock rims shocks 42222miles
i felt like the guy is just trying to screw me ova
please help me our has anyone ran into this problem
thank you evo lover 4 life
Old Aug 2, 2009 | 12:49 PM
chaotichoax's Avatar
bad alignments from the factory are nothing new
Old Aug 2, 2009 | 12:54 PM
alianum777's Avatar
Im assuming you are talking about the rear, cause the front has tie rods for adj. The rear bolt is actually an eccentric set up and why is it that you need a new bolt they saying? more info...
Old Aug 2, 2009 | 03:42 PM
nebevo's Avatar
thank you, your absolutely correct it was the rear, the mechanic was talking about. Mechnic told me he couldn't get it prefect toe alinement due to the rear "eccentric set up" "on both rear tires" Just as u stated above!
Mechnic said front is prefect but the rear is alittle toe. So more weight is on the inside of the tire if im correct? which well wear faster? of course thats a big no no for my new tires
So i guessing i gonna go look for this part buy it and put it on myself, Then have them alignment but due i really need it our is the mechnic just trying to "bs" me. i dont understand why Mitsubishi would due this unless i have aftermarket parts then i would understand if i need the fullyadjusttable bolt. But i dont have any aftermarkert parts . that's why im asking if im getting srewed
why im asking this question
I will put this part in no problem if it makes my tires have alinment better , Well the mechnic tould me $375 I just about **** my self. Just to install some fully adjusttable bolt for the rear to get prefect toe alinement in the rear. Thats why im asking
If i do need the nessary part where can i find it and please thank you
evo lover 4 life
hope this is better info
Old Aug 2, 2009 | 04:07 PM
cfdfireman1's Avatar
He's giving you a BS story. Tell us where this magic bolt is supposed to go please.
Old Aug 2, 2009 | 06:26 PM
EVOjuan623's Avatar
i work for tire kingdon in miami and that is bull**** i align my evo myself as i m certified in suspension and alignments the rear toe is an eccentric bolt that needs adjustment the rear of evos have toe and camber adjustment he needs to play with the camber eccentric bolt and toe eccentric bolt to get the toe exact in the middle i came across the same problem while aligning my car until i figured it out, he is an idiot and just wanted to make more money off you, hope this info helps
Old Aug 2, 2009 | 07:01 PM
huevosrancheros's Avatar
He wants to pull your pants down and aim for penetration, take your evo elsewhere!!!!
Old Aug 3, 2009 | 08:12 PM
nebevo's Avatar
thanks for the input guys&gals.
above ya the guy is trying to screw me ova
4mypsp
Nov 9, 2010 11:51 AM
fkw958
24
Mar 3, 2009 07:18 PM
SLVROZ_03
94
Jul 21, 2008 04:10 PM
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
12
Jun 15, 2006 02:13 PM
Zemo
Oct 5, 2005 11:04 PM
