Project Kics vs. Ichiba wheel spacers
Old Nov 6, 2009 | 12:42 PM
JDMevoBOOST's Avatar
Hello,
Is there any reason to go with one over the other here? I just got my 30mm front wide fenders, but still want to use the wheels that I have and sit them flush. I have Volk CE28, Work VSTX and the stock BBS.
It seems like these spacers come with their own studs and your stock studs sit inside the spacer. But if the spacer is not taller than the stock studs, then the stock studs will stick out through the wheel. On the Volks this doesn't matter because there are extra holes. The other two sets do not have extra holes, so it is more of a problem.
Does anyone know how far the stock studs stick out from the hub? Will a 25mm spacer be good enough that I don't need to shave down any of my stock studs? Any experience greatly appreciated. I am not really a fan of spacers to be honest, but I do want to be able to use the wheels I have acquired.
Thanks in advance for the advice.
-Ken
Old Nov 7, 2009 | 12:48 PM
Nobody have experience with both brands? I am going with probably a 25mm spacer, so is there any difference in quality?
Old Nov 7, 2009 | 03:58 PM
chu's Avatar
chu
I have both. Ichiba are hubcentric and the Project kicks are not.
Old Nov 7, 2009 | 08:13 PM
up's Avatar
up
I'd also appreciate it if someone can respond to the op's post. Thanks.
Old Nov 7, 2009 | 08:22 PM
PhoPoweR's Avatar
I have had both and I like ichiba because they are hubcentric
Old Nov 7, 2009 | 08:44 PM
whoang40's Avatar
Ichibia hubcentric and are better quality IMO.
Old Nov 9, 2009 | 09:06 AM
Nice okay I will go for the 25mm Ichiba. Will I have to trim the stock studs? It seems like 25mm is not tall enough to clear all of the stock studs?
Old Nov 9, 2009 | 09:29 AM
tsidrift1's Avatar
I have the ichiba 5mm spacers on the rear of my 1g talon. They are nice, I just hate replacing the studs with the extended ones. You are 25mm, so your should all be bolt ons anyway. I just picked up a set of 10mm project kics for the evo. I love them! I would say 25mm should be real close to coming out past the stock studs. The 10mm kics spacers cover most of the stud.
Old Nov 9, 2009 | 12:37 PM
Do you have a pic of your 10mm spacer on the hub with no wheel on?
Vizzle
27
Apr 17, 2015 12:13 PM
ever12
For Sale - Wheels / Tires / Suspension / Brakes
Jul 17, 2013 07:56 PM
TwStDeVo
Nov 10, 2009 08:46 AM
gsrboi80
Jun 9, 2009 08:33 PM
shunderwunder
Mar 8, 2008 02:09 PM
