Major Break Squeal
Old Jan 11, 2010 | 12:16 PM
Paintballer81's Avatar
Major Break Squeal
Whenever i stop my brakes squeal stupidly loud. When they heat up it just gets worse.
While i dont ever feel any slip in brakes it is just so god damn annoying... makes me feel like im in one of those beater ricers.
Old Jan 11, 2010 | 12:20 PM
Kracka's Avatar
More info is needed. What is your brake setup? How much use on them? The more details you give the better answers that can and will be given in return.
Old Jan 11, 2010 | 12:22 PM
stock brembos on my MR. Had the car checked out and both shops say the pads are still good. idk what else to say
Old Jan 11, 2010 | 12:26 PM
lude2evo's Avatar
did u just buy the car?
mine squel sometimes, mostly when cold. i think all evos do
Kracka's Avatar
Take the the pads out, clean and relubricate them. Remove the rotors and lightly sand the pad transfer off with 120-grit. Reinstall everything and go bed the pads back in, or, while everything is apart, take the opportunity to replace the pads with something better.
Old Jan 11, 2010 | 12:28 PM
GrimCreaper's Avatar
Stock pads? Do you do a lot of city driving? If you don't get the brakes hot enough to burn off the excess dust they will squeal. I've had that problem with Hawk HPS pads. Try cleaning them real good with brake cleaner and see if that helps.
Old Jan 11, 2010 | 01:07 PM
^thanks, i think it might be the dirt problem. an yes it does a good amount of city driving as i live about 45 min from LA. I will be gettin better pads in the near future but i just need a quick fix, well see if this works.
(had the car for about a month)
Old Jan 11, 2010 | 02:34 PM
borievoinitialD's Avatar
i have the same problem... changed rotors and pads in may 09' rotorpros rotors and project mu pads... i didnt replace the shims when we did the install..
could that be the culprit?
Old Jan 11, 2010 | 03:09 PM
Svendiesel's Avatar
Another location squeal comes from is vibration between the shims and pads if theres no hi-temp grease between them...or the shim that holds the pads in place thats held in by the 2 pins at the top and bottom of the caliper.
If that is not seated flat properly, you will get squeal up the wazoo from there. Put some hi-temp copper silicone on the pads where the metal wings contacts the pads. Vibration = Noise! Heres a picture of it, its labeled C. Got this picture from the "how to change your brake pads" in the how-to section to show you what Im talking about.
Old Jan 11, 2010 | 03:14 PM
so new shims, grease, and the red silicone can fix the squealing??
Old Jan 11, 2010 | 03:19 PM
Svendiesel's Avatar
You dont necessarily need new shims, I reused my oem ones when I put my Ferodo pads on. But the hi temp anti-sieze grease should definitely go between the pad and the shim inserts and that will stop any vibration there, and the copper silicone should go between the wings of the shim pictured above where it contacts the pads and that will stop vibration there.
Mine squeal a bit when cold, but only a tiny bit...but personally I like a little squeal lol.
joonvang
Nov 14, 2016 11:33 AM
mcjallen
Sep 26, 2011 01:03 PM
paul123
May 26, 2011 04:39 PM
Vengeance111
Oct 11, 2010 04:13 PM
j14mp
Apr 16, 2009 01:08 PM
