different width wheels with same width tires
Spacers up front would actually create more poke, rolling the fenders certainly helps you not rub if you are low but you still need the right tire sizes and offsets
Running lower et wheels up front is one solution
What offsets are you guys running on your 9s and 9.5s to make them fit well?
same size tires, same size wheels
if you want to mess with anything at all, do it with the offset. Even that I'll just buy me all the same offset wheels and then use spacer to move them out. They'll be a lot easier to sell when it's time for something new.
for me i stick with the Factory BBS and same sizes all around, and I rotate tires every 3000 miles.
Actually its everything to do with rice, All for looks not function. Historically this is a sub-forum for handling and performance, show n shine is for this crap. We don't go there and would be ecstatic if the herra-frushhrhhrh crew would stay out of here.
Lol silly fella calm yuh body before u get a heart attack
read my post its asking about a wider rear tire so as to increase rear grip. I am not asking about spacers ect. Read comprehend then post
Wheel width has very little effect on tire diameter but rated tire width with the same aspect ratio will definitely have different diameters.
My original post wasn't directed at your post, it was this thread in general. About your original question, no you cant. The "series" is directly releated to sidewall height. 45 series 245 will have (0.45*245) = 110.25mm side wall height and the 255 will be 114.75mm. That stacks on both side of the tire so overall diameter difference is 9mm.
gaspipedreamer
09+ Ralliart Show and Shine
1017
Jan 31, 2020 10:42 PM
antilag_200
17
Jul 31, 2013 05:12 AM
justin81
For Sale - Wheels / Tires
Nov 7, 2012 05:19 PM
whealy
14
Jul 29, 2010 07:25 PM
