tire size and pressure
Old Feb 9, 2010 | 11:25 AM
tarikul alam's Avatar
hi everyone our stock size is 235/45/17 if i go for 235/40/17 what would be the difference and tire presure for stock size i think front 32 rear 28 what would be the tire pressure for 235/40/17
Old Feb 10, 2010 | 09:53 AM
mr. happy's Avatar
Exactly the same pressure you ran as before. Yes you are lowering the sidewall which *should* make it stiffer, but you really shouldn't need to change the tire pressures any.
I personally raise the pressure a bit from factory to 33-35 front and 35-37 rear.
Old Feb 10, 2010 | 10:31 AM
Neal@tirerack's Avatar
I would run 32 all around to start and tune from there for optimum feel. Don't exceed the tire's max max psi.
Old Feb 12, 2010 | 12:51 AM
Aznknight47's Avatar
why would you want to run smaller size? it will change the speed if the over diameter is different from stock. and for tire preasure, it should be the same.
Old Feb 12, 2010 | 03:19 AM
4ukc's Avatar
the difference is not that big, I would`n change for 235/40 you will lower you evo better to use 255/40
Old Feb 12, 2010 | 06:51 AM
mr. happy's Avatar
Actually, it will change it. Slightly better acceleration, with a 1 or 2 mph hit at the top of each gear.
Usually people do stuff like this for AutoX and then just raise the rev limiter to get the best of both worlds
Old Feb 12, 2010 | 06:55 AM
thanks for all the input guys i live in bangladesh here i am not getting the stock size 235/45/17 here 235/40/17 is available and tire choice is also limited dunlop sp sport maxx and yokohoma s drive my ride is bone stock jdm ix gsr
Old Feb 12, 2010 | 07:55 AM
Smike's Avatar
But slower steering response. 255/40 can be heavier tires too.
Old Feb 12, 2010 | 12:32 PM
4ukc's Avatar
I dont think 1-2mile is worth that
Mike_Fugi
Aug 2, 2011 02:26 PM
mc14
For Sale - Wheels / Tires
Jun 27, 2010 11:43 AM
Blue8g
Midwest Region
Mar 18, 2010 11:48 PM
MIVEC 4G63
10
May 7, 2009 12:05 PM
rmevo9
Sep 15, 2008 06:43 AM
