View Poll Results: What rim width do you think is best
17x8.5
4.94%
17x9.0
43
26.54%
17x9.5
14
8.64%
18x8.5
11
6.79%
18x9.0
36
22.22%
18x9.5
42
25.93%
Other Please List
2.47%
17x8
2.47%
Voters: 162. You may not vote on this poll
Best rim size for every use on evo 8/9
Old Apr 23, 2010 | 05:24 AM
  #31
EVILBLOODBROTHA's Avatar
18x10.5 go big or go home Theres more tires for 18s then 17s, if your looking for wide tires that is
Old Apr 23, 2010 | 05:36 AM
  #32
FJF's Avatar
FJF
What is the reason for packing on all the weight at the worst possible point on the car?
Old Apr 23, 2010 | 05:39 AM
  #33
Gordian79's Avatar
i prefer stock size wheels and tires.cars ride like shat with bigger heavier wheels not to mention that it feels slower with big wheel/tire combo.For strip i use cheapy drag wheels with drag radials.Im also looking to go smaller to 16x8 fd wheels for the strip.
Old Apr 23, 2010 | 07:27 AM
  #34
Bassicfun's Avatar
17's are pretty common up through 265... and my issue is the close to $80/tire difference in cost from 17s to 18s, $320 a set difference... (Z1 star spec)
Always depends on individual application and requirements... 17x9s do well for me, I could consider 17x10s on the right offset though...
Old Apr 25, 2010 | 12:17 AM
  #35
RJones's Avatar
So you can run a 285/30/18 or 295/30/18.....
Old Apr 25, 2010 | 02:03 AM
  #36
ODUB's Avatar
I like my stock BBS wheels for everything personally. 255/40/17 NT05's
Old Apr 25, 2010 | 09:49 PM
  #37
So you can run a widebody, besides who said they had to be heavier then stock + more tire more grip
Old Apr 26, 2010 | 12:57 AM
  #38
smacksevo's Avatar
my vote is 17x9.
Old Apr 26, 2010 | 04:20 AM
  #39
FJF's Avatar
FJF
So you can run a widebody...
OK, for what reason?
...besides who said they had to be heavier then stock
I'll bite. Which 18x10.5 wheel weighs less than ~18lbs? Then, what about the weight of the tire?
Where, when, and doing what?
Old Apr 26, 2010 | 05:51 AM
  #40
A Time Attack
Well the RPF1s that are 18x10.5 are 19.7 pounds. Which is pretty *&%$ light for that size
Same as your first question, What ever I want, T/A, its called racing
Old Apr 26, 2010 | 05:58 AM
  #41
Domolution's Avatar
HAHA!!
18/x10.5 go big or go home! THAT'S RIGHT!!!
Old Apr 26, 2010 | 06:03 AM
  #42
FJF's Avatar
FJF
A Time Attack
Can you please link your stats? I tried looking for your thread in the Motorsports section, but only found a bunch of pics in Show and Shine.
OK, so they're not lighter than stock as you claimed. Add the weight of the tire necessary to take advantage of the width....
"What ever (sic) I want" hardly points to an optimized setup or an understanding of the dynamics at play. Is it my turn to roll my eyes?
Old Apr 26, 2010 | 06:42 AM
  #43
PKEVO8's Avatar
Sacrificing rotational mass for looks just seems illogical to me. A set of 17X9's coupled with *specs is more than optimal for the op. I don't think most people need to go much wider than 9" anyways
Old Apr 26, 2010 | 07:21 AM
  #44
jmelocik's Avatar
I prefer the stock Evo X rims on the Evo VIII/IX's its an 18x8.5, can be had fairly cheap, doesn't rub anywhere on the car or suspension, tires are pretty available, good contact patch size based on the weight of the vehicle, and they look pretty good in my humble opinion.
Josh
Old Apr 26, 2010 | 07:23 AM
  #45
GTWORX.com's Avatar
18's if you need "the look" or you need to fit bigger brakes.
Width will depend on tire size, and tire size will depend on what you use your car for (hopefully).
17x8 (maybe 17x8.5) is the most fun in my opinion and looks plenty good with the right wheel.
Just my opinion.
- Andrew
