Aftermarket camber plate pillowball mount replacement for Megan coilovers
One of my front pillowball mounts on my Megan coilovers is wornout and clucks are big bumps. Is it possible to install the Cusco or Works pillowball mounts on my Megans?
Is this the sound you get when you hit a bump and there is like an intense clicking sound from the coilovers? Ive been getting this recently and been trying to figure out why.
Let me know if you find a solution! Thanks.
Clicking sound? No you will hear a clunk sound if things are getting play in them. The only other sound coilovers "should" make sometimes is a spring binding sound if the isolator pads are missing or broken. Otherwise they should be pretty much silent. Go make sure your adjustment collars are not loose also.
Are you sure its worn out? Have you tried tightening the nut on top and making sure the collars on the coilover are tight? If yes to both of these questions you can grab a set of Tein Tops.
muster
Jan 30, 2016 09:08 PM
McSlides
Nov 9, 2013 12:26 PM
eastcoastoutlaw
Oct 3, 2013 11:10 AM
