Evo 8 centerbore question
Old Mar 17, 2010 | 03:08 PM
FL_SilverEvo8's Avatar
Ok I know the Evo has a 67.1 centerbore. I was looking at a picture of a rim and it has:
"73.0HB e35pcgm"
Does that mean 73.0HB is the centerbore and e35 is the offset? If it is with it being 6 off on the centerbore would I be ok with out center ring adapters? A 35 off set is the stock off set anyways so I don't have to worrie about spacers. Right? I just did a search and found the stock evo rim is a 38 offset. I don't know what one it is.(35 or 38 off set) Some people are saying 35 and some are say 38. (pulling hair out of head)
I also want to know what tire size should be run with size rim. I was thinking hence the stock tire size is 235/45/17 if I should just go up to a 245/40 or 45/17. Would the stock size be alright or would it bulge ?
Thank you everyone for your time looking over this.
Old Mar 17, 2010 | 03:17 PM
chu's Avatar
chu
You are correct on the center bore issue. You'll need hubcetric rings with a 67.1 i.d, and 73 o.d. As for the wheels, you must consider the size of the wheels when looking at offset. What size are the wheels you're looking at?
Old Mar 17, 2010 | 03:55 PM
Oh they are 17x8.5.
Old Mar 17, 2010 | 06:16 PM
chu's Avatar
chu
+35 should work. Tire side depends on what you are doing with the car. My opinion is 245/45 is the smallest you should go with, and ideal for a daily driven Evo. 255/40 is something I'd go with since I dd/autox.
Old Mar 17, 2010 | 08:34 PM
cool thanks
anyone else have some in site?
Old Mar 18, 2010 | 08:27 AM
Neal@tirerack's Avatar
+ on on the bore/offset info. Many also use a 245/40 with good results. If you plan on lowering the car I would run the 40's instead of 45's to avoid possible rubbing.
Old Mar 22, 2010 | 08:00 AM
Would a 245/40/17 be ok on a 8.5 rim?
Old Mar 22, 2010 | 08:02 AM
Yup! 8.00 to 9.50" wheels.
goofygrin
88
Jul 24, 2022 08:22 PM
tmaddox
For Sale - Wheels / Tires
Mar 23, 2016 03:02 PM
tmaddox
Feb 10, 2016 06:29 AM
soceur77
Aug 5, 2013 12:38 PM
kekek
Dec 15, 2006 05:53 PM
