Caliper seals cracking
For those who track their cars:
You've undoubtedly noticed the caliper color change, but have you taken a look at the piston dust seal? After just 2 events, the seals in my calipers are cracking, and brittle from the heat. Once the seals are worn thru like this, dust and moisture can enter around the piston, and affect the piston seal. That would be disastrous.
Anyone else notice this? If not, check your calipers the next time you change out pads.
Originally posted by value
Sorry to hear that. Time for a upgrade ??
Originally posted by HOLLYW00D
what happened to the first one?
Wow what happened? looks like you t-boned a telephone pole or something.
I have not checked my calipers yet but I was planning to rebuild my front calipers soon anyway. After reading your message I just ordered the rebuild kit from the dealer.
Front rebuild kit retail - $140.76, club DSM price $85.65
It should include new dust seals, I will let you know how it goes.
I am not surprized that the dust caps are cracking. Almost all the calipers that I have used crack the dust cap if used on the track (especially so if used with race pads). I drove around for 2 years with cracked dust caps before rebuilding the calipers. But I did stay away from rain and also no winter salt driving.
FYI, the Wilwoods do not even bother putting a dust caps in. They say to rebuild these often, but I did not do so for 3 years (~10K miles without issues) and it was just fine.
Oh, and I seriously doubt that extra cooling ducts will help your dust cap life. The ducts will help your rotors cool off faster, but I doubt it will help your dust seal life...
The solution would be to see if anyone makes high temp dust caps, made from similar material as the caliper piston seal.
Where do you get the Club DSM pricing?
And dolet me know how the install goes, and what is the condition of the seals etc..
oh man! is that from brake malfunction due to cracked dust caps??? that looks horible, glad you walked away.
(and no, it wasn't me driving - I don't do that)
I currently have over 19K with several track days and I drive the car extremely hard on and off the track. I replaced the brake pads at around 10K, the dust caps looked fine at that point. The only thing that I might be doing differently is after every lap session and cool down lap, I keep right on driving for another 10-15min on the roads near the track to let the brakes cool. I believe that the thick, heavy, stock rotors just hold to much heat and a 3-4min cool down is just not enough after severe use.
One time I did not bleed the brakes between track days and managed to boil the brake fluid, I pulled in and did not do my usual cool down. I bleed the brakes and tried to go back out but ended up with pad transference. After properly skimming the rotors and continuing my cool down procedure I have not had another problem like that.
I used Carbotech Panther plus pads back at 10K, they are great on the track and actually dusted less than the stock pads, but they are noisy and after several thousand street miles they eventually ate the rotors. So I am looking for new rotors, once I get them I am switching back to the stock pads and will rebuild the calibers, probably within the next 2wks.
BTW for those who have never done this, caliper rebuilds are very easy to do.
A lot of the Mitsu dealers provide discounted pricing to club DSM members (it's a forum just like this one) http://www.dsm.org/g/ClubDSM.jpg , I believe each dealer has a different discount rate, I found that my local dealer gives a very substantial discount (30-40% depending on the part)
. All you have to do is tell them you are with ClubDSM and ask for the discount.
