Caliper seals cracking
Originally Posted by ghibliss
They will tell you that the torque for the bolts will not come out correctly if there is paint or powder where the bolt heads seat. That you should never attempt to separate the two machined halves of the caliper.
Ditto. When I rebuilt the 4-piston calipers on my Z, I never saw any need to separate the two halves of the caliper (nor re-powdercoat it). I'm not sure I follow what you're saying...
Originally Posted by trinydex
I ran the Girodisc titanium shims and had no problems. The problem is, you have to run a more aggressive brake compound. Since the heat doesn't escape as easily out the back of the pad into the caliper, it gets trapped in the brake pad and heats it up more than normal. My DS2500 pads totally melted, coated the rotor and wheel with chunks of brake material and warped my rotors as the uneven melted brake transfer material caused hot spots on the rotor.
It's all a give and take.. what are you willing to compromise for performance?
Caliper rebuild kits done
Hello All,
Came up with a source finally for the rebuild components. All parts are genuine Brembo pieces. Kit includes 2 x 40mm piston seals, 2 x 46mm piston seals, 2 x 40mm dust boots, and 2 x 46mm dust boots. Price is $85 per caliper. Was hoping to put together a group buy as I cannot guess how long these will be available to me. I'm kinda backdooring them alittle...;-) If you think you want or need them, order them now, otherwise I may loose out and everyone will be back to $120 at the dealer.
Get the Ti shields while you're at it and make your new seals and boots last longer. I'll throw in free shipping to those purchasing both Ti shields and rebuild kits. PM or e-mail me if you are interested. martin@girodisc.com
Thanks,
Martin
Thanks,
Martin
Raptord
28
Jun 22, 2018 08:06 AM
jingalalahoe
Sep 9, 2016 12:44 AM
Treyzian
35
Mar 31, 2016 10:36 PM
fireroasted
May 11, 2012 12:01 AM
