The car did....... so so
Old May 26, 2010 | 03:46 AM
  #31
blkmkIII's Avatar
Originally Posted by ODUB
like others said, your camber is too high in the rear. I'd run 1.5 or less. currently my car is setup at -2f/-1.2r 0 toe all around. as for the tire pressures, I don't know about the Z1's, but on my NT-05's I run 36-38 up front, and 34-36 in the rear. I'd try dropping from 39 to what I usually run.
also, I've seen a few threads on this with different opinions, but from my experience, running slightly lower pressure in the rear tires gets the car to rotate better. I'd always thought it should be the other way around, but after trying it out, it seems to work. good luck
thread/
Old May 26, 2010 | 07:24 AM
  #32
GTWORX.com's Avatar
Less rear camber and/or more front camber if you want to go to camber plates.
- Andrew
DjMarcus
08+ Lancer Show / Shine
Aug 31, 2012 01:42 PM
MonsterParadise
Jul 23, 2012 12:00 AM
rrd
Jun 22, 2012 09:21 AM
ApexEVoIX03
50
Jan 5, 2012 03:41 PM
il2az
17
Jul 13, 2005 11:00 PM
