Evo 8 Front Camber Kits
Old Jul 3, 2010 | 09:14 AM
racer135's Avatar
When I changed the oil I noted that one of the tires was worn on the inside. Camber on that wheel was -1.8 and could not be adjusted more with stock camber bolts.
Which is a good front camber kit for the Evo 8? Are all of them about the same. It is just a eccentric bolt.
Old Jul 3, 2010 | 09:16 AM
meckert's Avatar
Camber isnt causing the wear--its your toe.. Have it aligned and toe set to 0 and you will be fine.
Old Jul 3, 2010 | 09:39 AM
racer135's Avatar
Thats what I suspected also. Maybe the camber changed (bolt moved) and that changed the toe. I moved the tires to the back but one is almost at the threads and they only have 10K miles. I hope they are OK in the back.
Evo Sportback
Oct 27, 2014 05:49 AM
gunhaha
Jul 24, 2014 12:43 PM
Jake26
MitsubishiParts.net - WA
Feb 5, 2011 07:29 AM
Crz10
13
Apr 29, 2007 02:39 PM
AhmadHasib
Jun 12, 2006 11:00 PM
