Brake problem! plz help!
Old Jul 8, 2010 | 03:23 PM
06GraphiteEvoIX's Avatar
My 2006 evo ix just recently had new pads put on and they sqweeek! not everytime but about 1/4 of the time and it really sounds bad of course, when you roll up in an evo and the brakes are like "EEEEEEEEEEE!" its horrible and i cant figure out why they are doing it... any suggestions? it does it most only the front left but the other day i took the front drivers side apart and put them back together and it still does it somewhat but now it is on the passenger side and im trying to see if anyone has had the same problem or if it is something i did wrong? plz anything helps
Old Jul 8, 2010 | 03:28 PM
NewEvolutionIX's Avatar
Brakes!! Who uses brakes? Evos are meant to go fast PERIOD. lol
Did you do the brakes yourself? And if so did you put grease in the proper places?
Old Jul 8, 2010 | 04:46 PM
Smike's Avatar
Which pads?
Old Jul 8, 2010 | 05:59 PM
cfdfireman1's Avatar
really?
search
Old Jul 9, 2010 | 02:02 PM
They were checker's/o Reilly's premium brake pads.... where should i put grease? yes i did them myself but i didnt grease anywhere. That is most likely the problem
Old Jul 9, 2010 | 03:52 PM
barneyb's Avatar
Reuse the OEM shims. There are tire rotation arrows punched in them if you are not sure how they go on. Grease where the shims and caliper pistons meet.
Old Jul 10, 2010 | 12:56 PM
The only thing i change was the pad and the little paper backing that goes on there. Is that the Shim? i know nothing about brakes as you can tell. Although as i have been driving i havent heard the brakes since the a day or 2 after i took my drivers apart and put it together so maybe the pad was just sitting slightly wrong and rubbing but with my luck it will come back
Old Jul 10, 2010 | 01:23 PM
Smike's Avatar
Those are terrible pads. And if you do not know about brakes, I strongly do not advise working on your own car. That is a safety measure. I recommend finding a good shop in your area, go in, talk with and watch the mechanic. Then next time, you will be more prepared to work on them.
Old Jul 10, 2010 | 01:46 PM
barneyb's Avatar
Maybe you got it fixed.
The shims I was referring to are steel. I've had several sets of pads on my car and I have always reused these shims over whatever came on the replacement pads with good results.
slowsrt4:(
Dec 15, 2014 03:18 PM
VIIBHR
Dec 23, 2012 11:26 PM
daechul2da
Sep 3, 2008 06:48 AM
05evo8noob
Aug 26, 2007 04:57 PM
EVO-8-Silver
Oct 11, 2005 10:11 PM
