X BBS Wheels on Evo 8 Question
Old Aug 1, 2010, 06:55 PM
Donkeypuncher's Avatar
I just bought a set for my 04 RS and had a couple of questions.
1. Can you use stock lugnuts from 8 Enkei?
2. ANyone ever use spacer? If yes how big can you go or suggest?
I wanted a more agressive look so was considering using spacers. Wheels are 18x8.5 +38 I believe.
Thanks
Old Aug 1, 2010, 09:58 PM
chaotichoax's Avatar
stock lugs will work
spacer you could go up to 8mm before you'll need to roll the rear fenders assuming you are running a 245+ tire and you are lowered
if you want a more aggressive look why buy a stock wheel set?
Old Aug 2, 2010, 05:17 AM
Thanks for the input! I got a pretty good deal on the wheels so I figured I would try them out and trade up if it was too simple looking. I will be running a 245/40/18. If I rolled fenders, could I go 15mm?
Old Aug 3, 2010, 04:33 PM
bump
If I rolled fenders in rear, could I go with a larger spacer? ANyone use a spacer with this set up?
Old Aug 4, 2010, 07:01 AM
Received 1,384 Likes on 1,317 Posts
You may be in un-chartered territory. Im running the X wheel w/ a 255/35 tire & Ive tried a 5mm spacer but ended up removing them due to vibration (Rear fenders not rolled)
The X BBS is the same spec as the GSR (as far as I know) 18 x 8.5 +38. By adding the 15mm spacer you are effectively running a +23. Give it a try!!!
You may need aggressive rear camber to make it work right.
I would think the fronts would work well
Peace
Old Aug 4, 2010, 11:42 AM
Cool, thanks!Ill try the 15 and if it doesnt work, ill go with rolling the fenders next.
Old Aug 4, 2010, 06:40 PM
^^^My good guess is that you will certainly need to roll the rears
Love to see it after the install=)
dawidevo
Mar 19, 2015 09:17 AM
striderx88
16
Jun 1, 2010 07:42 PM
UncleXSO
26
May 19, 2010 03:04 PM
bluebyuevo8
Apr 27, 2005 05:35 PM
EVONation
Oct 22, 2003 05:02 AM
Quick Reply: X BBS Wheels on Evo 8 Question
