Clutch Master Cylinder Resevoir??
Here's the story:
Last year while running the autocross, I had MAJOR brake fade. Afterwards, I decided to get some DOT 4 brake fluid and bleed the system. At the time I was pretty busy with school and work so I didnt have time to go back to the autocross, but I noticed my clutch enguagement point started moving further and furthur down during fast shifting. During a span of about two months I had re-adjusted the clutch about 4 times, each time adjusting from the floor back to the middle as per my driving preference, when the clutch started slipping. However, ever after I installed the new clutch the enguagement point was still inconsistant during quick shifting.
*Bad clutch master cylinder* But why?
Doing some research I found that DOT 4 is not supposed to be used in the clutch master cylinder as it damages the seals. So now what? We only have one resevoir to pour DOT 4 in for the brakes and DOT 3 for the clutch.
Has anyone ever heard of, or tried using a seperate resevoir for the clutch master cylinder? I was out in the junkyard yesterday looking for a resevoir in any manual drive vehicle that i can find but had no luck.
Any help would be greatly appreciated. Thanks.
Do you have a source for the brake fluid ruining the master?
Thanks
Thanks
Here's the story:
dot4.
but yeah i had the same issue with the clutch. replaced the master and the slave(slave went but you have to replace both) with SS clutch lines and its been fine since. it could be bleed wrong or not enough.
The First thing to do is to bleed all of the fluid again to ensure no air is in the system...The brakes and the clutch because they share the same reservoir. Dot 4 fluid will not ruin anything, it is brake fluid. I have been selling Dot 4 fluid to Evo's for a long time.
Bleeding via the 2 man system with one pumping and one bleeding is the best way.
Hope that works for you.
- Joe
P.S. I am an ASE Master Certified Technician
- Joe
Drift4
26
Sep 2, 2016 11:31 PM
gooov
13
Mar 19, 2015 04:41 PM
Rasputin
Lancer Tranny/Drivetrain Tech
31
Jul 16, 2012 07:04 PM
