when is revalving needed
At what point would you need to revalve your struts when upping your spring rate?
Is a couple k higher ok to run on the same valving? I was looking into some ohlins if that helps.
Thanks
Thanks
Assuming the damping is in the correct range in the first place....
If Ive looked at the equation correctly (a little rusty on vibrations), you can find the change in the damping ratio with w2 = w1*sqrt(r1/r2) where w is the ratio and r is the rate.
Or the percentage change with just sqrt(r1/r2). So if you went from a system at ~0.65 damping ratio and 8kg/mm springs the change would be w2 = 0.65*sqrt(8/10) = 0.58.
Id say pushing much further past that is really getting passed an optimum damping force. Granted we have curve profiles to consider and adjustable dampers to compensate. But for example sake this should hold.
ddlopresti
Oct 6, 2016 11:09 AM
Nazarite
Mar 14, 2016 01:50 PM
SikofFalln
43
Dec 2, 2015 05:43 PM
dsmdeliveryboy
Nov 14, 2007 08:03 PM
